Built HR P0345 crazy problem
Old Mar 19, 2011 | 07:44 AM
Jasonvs2146's Avatar
Jasonvs2146
Default Built HR P0345 crazy problem
Motor Backround
CP Pistons, GTM H beams, ARP head Bolts, HKS Head Gaskets, BC Springs and Retainers, Block Guards
So the other night while driving my car suddenly started to run horrible. Misfiring and all. Took it back to the shop to pull the codes. It was throwing 1 code P0345. Bank 2 Cam Position sensor. So we went ahead and replaced the sensor. That did not solve the issue Since we have
Changed ECU, Swapped the Oil Solenoid from one bank to the other to see if problem followed, check for spark, check injecors. We then ran a cipher log and found that bank 2 was pulling 63.5 degrees timing?!?!? Ill attach the full
log.
INTK CAM TIM-B1 (Deg CA) INTK CAM TIM-B2 (Deg CA)
5 63.5
5 63.5
5.5 63.5
A/F WB-B1 (V) A/F WB-B2 (V)
2.08 5.065
2.105 5.065
2.1 5.065
2.02 5.065
Any help would be greatly appreciated. I assume its mechanical just have no idea where to start
Link to excel file.
http://www.sendspace.com/file/nxyfxd
Old Mar 19, 2011 | 10:56 AM
Jasonvs2146
We have Nats disabled with Osiris .. I don't see how it could b NATS anyway
Old Mar 19, 2011 | 11:43 AM
nismonian's Avatar
nismonian
good luck br0, hope you get it fixed!
Old Mar 19, 2011 | 11:49 AM
Jasonvs2146
Looks like a broken Cam I'll kno soon
Old Mar 19, 2011 | 02:54 PM
Jasonvs2146
Oh Hell yea man BROKEN CAM!! Yess
This cars the devil
So the cam doesnt rotate. The cam gear in the from does but the shaft does not.
Old Mar 22, 2011 | 06:26 AM
kramykram's Avatar
kramykram
ouch that sucks ballz compared to the quick stop
Old Mar 24, 2011 | 06:10 PM
stock07g35s's Avatar
stock07g35s
Did you build this as an interference motor? (piston to valve) If not, slap another cam in and roll on. Otherwise... a lot of hurt. I had another car where the adjustable cam gear bolts walked out while rolling. Scary as hell. My heart dropped. Bought new bolts and installed lock washers and didn't skip a beat. Good Luck.
Old May 10, 2011 | 10:17 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Bump any resolve Op?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
