Some HR questions ... need answers??
Old May 3, 2011 | 01:45 PM
ChrisNI's Avatar
ChrisNI
Smile Some HR questions ... need answers??
Hi guys ...
Have a couple if questions regarding my HR zed ...
- colder plugs , do they make any difference and which ones are the best to go for? My car only has 12000 miles on it but part of me wants to change for a better product? Advice?
- also I've modified my HR a good bit:
Kinetix HFCs
Nismo y pipe back exhaust system
Stock hr y pipe
Stillen gen 1 intake
Uprev Osiris remap
Is there any thing else worth doing or changing for more power ... avoiding forced induction I.e. turbo and charging it.
Thanks in advance guys
Chris
Old May 3, 2011 | 02:54 PM
archangel72's Avatar
archangel72
https://my350z.com/forum/engine-and-...installed.html
Old May 3, 2011 | 04:58 PM
Lakeside's Avatar
Lakeside
Personally I would ditch those Gen 1 CAI's for the stock airboxs. Or goto a Gen 3 or Injen.
Gears & diff are a huge improvement! If you have the cash, headers will squeeze out alittle more HP. Or you can do an NA stroker build with or without cams!
Old May 3, 2011 | 10:31 PM
supanam's Avatar
supanam
wider tires - lighter rims - coil overs - sway bars.
won't give you more power but makes the car so much more enjoyable to drive!!!
Old May 4, 2011 | 12:43 AM
ChrisNI's Avatar
ChrisNI
Thanks Guys,
Ive also made other modifications ...
XYZ Coilovers
Ferodo pads all round
Its currently on Volk GTS Wheels 9.5/10.5
I am definately going for an ARB asap.
Would the Gen 3's make much difference? Power wise? I was thinking about them and possible an XYZ pipe with race cat?
For an N/A Stroker build what all parts do you need and what type of power would this achieve?
Old May 4, 2011 | 01:53 AM
KingBaby's Avatar
KingBaby
Hardest Setting
What is going on?
Old May 4, 2011 | 05:51 AM
Lakeside's Avatar
Lakeside
http://www.gtmotorsports.com/search....=search&page=1
Check out GTM's website. They will ship international. They can also help you with tunes.
CAI's wont make much power but those Gen 1's are worse then the stock airboxs. Your pulling in engine heat from under the hood. Which is CRAP!
Old May 4, 2011 | 06:02 AM
NZMOWND's Avatar
NZMOWND
Old May 4, 2011 | 06:29 AM
stock07g35s's Avatar
stock07g35s
Cams, pulleys, tune, gen 3 intake, gears, weight reduction, headwork?
There are things you can still work on. All together, it adds up to the price of FI.
Sucks, doesn't it.
Old May 4, 2011 | 06:34 AM
redline06's Avatar
redline06
ditch the gen 1 intake and get the long tubes or stock air box with k&n drop in filters, also yes an xyz pipe is great. i have test pipes -xyz pipe with resonator and nismo s-tune exhaust and it sounds amazing with no rasp.
Old May 4, 2011 | 06:39 AM
Lakeside's Avatar
Lakeside
I wasn't aware there was a complete HR pulley set.?
Old May 4, 2011 | 05:50 PM
AadosX's Avatar
AadosX
Yes Gen 3's and an aftermarket Y-Pipe..
Old May 4, 2011 | 06:09 PM
doshoru's Avatar
doshoru
Gears will have more effect on N/A than anything, short of a fully built motor.
Old May 4, 2011 | 07:13 PM
drdave2387's Avatar
drdave2387
Just for the record, I don't know if they are on the shelf or not yet but NGK is now selling the plugs at their cost instead of HKSs costs because hks only had rights to them for 2 years and NGK made them to start with...once I find the part number again I'll post it but the colder plugs are only 6.99 instead of 24.99 now but I've went to a few autoparts stores and they didn't have them in the books yet...according to my friends source at NGK, they should be on every autoparts store's records soon...
Old May 4, 2011 | 07:24 PM
350ztttt's Avatar
350ztttt
Which gears are better? I heard the 4.03whatevers give you no traction below third...how much are the other ones (3,7??)? I know nothing about these mods.
Old May 4, 2011 | 07:25 PM
midz350's Avatar
midz350
The VQ37VHR spark plugs are one step colder than the VQ35HR ones.
DENSO
PLUG TYPE FXE24HR11(SIP IRIDIUM)
DENSO PART NUMBER 267700-6970
OEM PART NUMBER 22401-JK01D
MAKER NISSAN
SPEC MODEL NAME NISSAN SKYLINE COUPE / INFINITY G37 Coupe
MODEL TYPE [370GT] DBA-CKV36
ENGINE TYPE VQ37VHR
DISPLACEMENT 3,696cc
Number of Cylinder V6 DOHC
PLUG TYPE FXE24HR11
Old May 4, 2011 | 07:32 PM
CTZ860's Avatar
CTZ860
Are all you guys recommending the gen3 intake actually running it yourself?
I'm surprised to see so many recommending it as most of what I have read said its not worth it. From what I've read some people actually experienced losses with this intake as the air has to travel longer etc. etc.
Anyone got some real proof if it's worth it or not?
Old May 4, 2011 | 07:37 PM
midz350's Avatar
midz350
OEM air box's > any aftermarket intake tubes to date. period.
Old May 4, 2011 | 07:51 PM
350ztttt's Avatar
350ztttt
I have gen 3 equivalent from injen. maybe 3 whp to be honest, but combined with other mods is when a difference is really made. Any mod alone doesn't do much, and if you have stock cats on, anything before it is generally worthless because the cats just restrict their potential...
Old May 4, 2011 | 09:52 PM
ace32x's Avatar
ace32x
before i went fi i had
Greddy TiC true dual exhaust with resonators removed and AAM 2.5" testpipes
CoBB AP
Injen intakes
KaZZ 2 way lsd
and some suspention work stance GR + coilovers and hotchikis sways.
Dyno'd at 298.4 whp on a DJ with all that ^
if ur planning on staying NA id get gears/ a 1.5 or 2 way lsd some form of 2.5" dual exhaust with test pipes tune and some injen intakes and call it a day
