Some HR questions ... need answers??
Old May 5, 2011 | 07:07 AM
Lakeside's Avatar
Lakeside
Thats what I dyno out at. 296-299 whp with all my mods.
4.08 Gears really wake up the car with my current mods.
Zim
Old May 5, 2011 | 08:07 AM
AadosX's Avatar
AadosX
Originally Posted by CTZ860
Are all you guys recommending the gen3 intake actually running it yourself?
I'm surprised to see so many recommending it as most of what I have read said its not worth it. From what I've read some people actually experienced losses with this intake as the air has to travel longer etc. etc.
Anyone got some real proof if it's worth it or not?
Um look at my post first post in this thread then pay attention to my sig.
Originally Posted by midz350
OEM air box's > any aftermarket intake tubes to date. period.
And you can feel free to search my user name for my thread with dyno results showing real gains. 8 peak rwhp gains and negligible losses under the curve from Injens ON A DYNO (they would make more of a positive difference than that in real world applications).
Old May 5, 2011 | 02:57 PM
midz350's Avatar
midz350
Until the engine bay heat up and those metal pipes get really hot and you lose your 8whp and maybe more
Old May 8, 2011 | 04:30 PM
AadosX's Avatar
AadosX
I'm no scientist but I don't think aluminum holds heat very much. This is why I can cook a pizza on some aluminum foil and immediately grab it and pick the foil out of the oven.. try that with a baking sheet lol.
I'll be sure to grab a pipe after a long trip and see for myself though.
Old May 8, 2011 | 04:40 PM
Lakeside's Avatar
Lakeside
^^^^ lol
Old May 9, 2011 | 08:37 AM
Rubidium's Avatar
Rubidium
Alright so dyno'd the other day.....current mods: Stillen Gen 3 intakes, Unorthadox Lite weight pulley's, ACT lite weight flywheel and heavy duty clutch, COBB AP stage 1 map. Base line Dyno on Blue350zed's stock was 254 on this dyno.....now I know it's not my car but the best baseline I can go off of (same DYNO, same location, he drives and 07 and I an 08).
Yes A/FR was pretty bad, going to get a custom soon, they told me the believe with a good tune they can hit 283whp min with tune on current setup. Pretty good considering I'm running complete stock exhaust. This number was from a pull in 4th, we did a pull in 5th (car got up to 160mph ) but not as much power.
Old May 13, 2011 | 08:06 AM
AadosX's Avatar
AadosX
You need to do a 5th gear pull.. that's the 1:1 gear, otherwise your dyno is worthless for comparisons here. But it should mainly just be used by you to compare upgrades to see the power they made.
I would definitely ditch the Cobb, especially since they say all over the place to not to use their maps with intakes. :shame:
Lastly if those AFR's are taken from a sniffer then I wouldn't really pay any attention to them.. especially since you have cats.
Old May 13, 2011 | 08:17 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Where is the rule on what gear to be it, on the dyno to be 1:1! Possible a link? In the last week I've been to two different shops. One said fourth, other said third, none said fifth.
Old May 13, 2011 | 08:50 AM
AadosX's Avatar
AadosX
Here's what I know about it.
On the Z's if you look at the transmission gearing, 5th is the 1:1 with the engine.. so that's where that comes from. Now I think it depends on the dyno which gears read lower or higher, since different dynos work in different ways.
Of course the main thing that matters is that you just always do it the same way for your own records.. but the most common way to dyno Z's and G's is definitely in 5th because that's the 1:1 gear, so that's what you should do if you're trying to dyno race on a forum lol.
Old May 13, 2011 | 09:20 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Cool...I'm all about racing online, that's why I was alittle sad at my weak numbers...ahahahaha
Next time I'll be more in charge of my dyno pulls instead of the shop doing what they normally do.
From my dyno on a dynojet I was 15whp behind a 370z whose previous dyno on that dynopack was 315whp on the dynojet. So that's the only reason I had hopes of that math panning out in my favor aswell. Then again so many variables, and lack of good dyno operators here on island.
Now I know thanks!
Old May 13, 2011 | 02:33 PM
Rubidium's Avatar
Rubidium
Well you're correct! He (Justin at RPM) didn't do a print out of all three runs, but we did pulls in 4th, then 5th, then 4th again. I'll see if I can get the print out or I'm just going to get it tuned and use those gains.
Old May 13, 2011 | 03:24 PM
I like this motor. It is making horsepower AFTER 6,500 RPM. Torque appears to drop after 5,250 RPM, but the drop is not substantial. Overall I like the tune.
Old May 16, 2011 | 04:19 AM
ChrisNI's Avatar
ChrisNI
Spark plug wise ... what seems to be the best for these cars?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
samansharif
Sep 25, 2015 12:31 PM
