thinking of changing cams
Old Oct 9, 2011 | 06:01 AM
styy81's Avatar
styy81
Default thinking of changing cams
i intend to stay NA, does changing cams worth it for HR engine? I have stock engine with bolt on like exhaust,tp and drop in filter with Osiris tune.
Old Oct 9, 2011 | 08:48 AM
Rubidium's Avatar
Rubidium
Blue350zed did 264 cams and got some more power but lost some responsiveness.
Old Oct 9, 2011 | 11:48 AM
SE5spd's Avatar
SE5spd
I wouldn't.
Old Oct 9, 2011 | 01:28 PM
MM'08_350Z's Avatar
I also did 264/264 cams and true dual and Okada coil packs
And went from 289whp->309whp->315whp and I'm pretty prety happy with that set up. All done on the same Dyno
Old Oct 11, 2011 | 02:44 AM
styy81's Avatar
styy81
Thanks
Old Oct 11, 2011 | 07:17 AM
SoCal07HR's Avatar
SoCal07HR
So you gained 20whp from the cams and true dual and 6whp from the okada coil packs? That's not bad at all, I haven't read about anyone with those coilpacks yet.
Old Oct 11, 2011 | 09:03 AM
Chako135's Avatar
Chako135
they're only $1000..no biggie
Old Oct 11, 2011 | 09:57 AM
SE5spd's Avatar
SE5spd
for that price you just get a bottle and gain 100+whp if you want.
Old Oct 11, 2011 | 10:28 AM
SoCal07HR's Avatar
SoCal07HR
$1000 isnt too bad, considering there isn't really that many upgrades you can even do to without spending that or more if you want to to it right.
Old Oct 11, 2011 | 10:34 AM
SE5spd's Avatar
SE5spd
just did a quick search for HR cams.
$1378.00 for the cams, then if you wanna do valvetrain and that stuff thats more, then theres install and retune which is atleast 800 together.
288 degrees @ .012”
245 degrees @ .050”
11.50mm Valve lift intake and exhaust
Old Oct 11, 2011 | 02:42 PM
stock07g35s's Avatar
stock07g35s
Can we get unground billets for the HR?
Old Oct 11, 2011 | 02:51 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
+ install + tuning...double that amount and you'll still be short
Old Oct 11, 2011 | 03:55 PM
MM'08_350Z's Avatar
They work awesome for now. But I'll give those coilpacks another 5000 miles and then I'll make a review on them.
Old Oct 12, 2011 | 04:47 PM
biggersNISMO's Avatar
biggersNISMO
It sucks there's not an independent test for just the cams.
But still, good gains.
Old Oct 12, 2011 | 06:38 PM
Rubidium's Avatar
Rubidium
What is the difference between DE cams and HR cams?
Old Oct 13, 2011 | 06:15 AM
Z1 Performance
Former Sponsor
completely different engines
Old Oct 26, 2011 | 06:03 AM
blue350zed's Avatar
blue350zed
I didn't lose any responsiveness, it just shifted the power band over a bit.
I talked to Adam at Z1 several times before settling on the Tomei 264's. Couldn't be happier with 'em.
Old Oct 26, 2011 | 09:10 AM
Chako135's Avatar
Chako135
If I were to get cams, those would be the ones ^
Old Oct 26, 2011 | 03:47 PM
Rubidium's Avatar
Rubidium
That's not what Justin told me
I'm going to get cams after I decided weather or not to go with those FI LTH's or just wait for motordyne's. If I do the wait (for motordyne) then I'll get cams first.
Old Oct 26, 2011 | 05:10 PM
SoCal07HR's Avatar
SoCal07HR
Cannot wait for Motordyne's headers. I need to call Tony and get more info on them. I'm planning on cams, springs, and a retune once they are available.
