Uprev Tune or NItrous
Old Jul 15, 2012 | 09:22 PM
!Z!'s Avatar
!Z!
Default Uprev Tune or NItrous
I'm sure this isn't in the right section.But my problem is that i am going to have some extra funds this week; and want to know should i order my uprev tune or my nitrous kit? Within the next two weeks i will buy the part that is left i just want to know which one i should get tomorrow.
And if you say nitrous should i order the Dynotune kit or Zex i read that a lot of people are having problems with the ZEX control box.
Old Jul 16, 2012 | 01:40 AM
brandon kak's Avatar
brandon kak
im interested too, Im looking to do nitrous too. Im just unsure where to start ordering! From what i have read, i need a nitrous kit, uprev to retard timing, bottle warmer, bottle opener, full throtle sensor, rpm sensor a/f gauge. And some other goodies im unsure about.
Old Jul 16, 2012 | 06:55 AM
lillong1991's Avatar
lillong1991
You need to tune the car in order to get the most of of your nitrous set up and for it to run correctly...
Old Jul 16, 2012 | 07:30 AM
!Z!'s Avatar
!Z!
So i guess that is the answer then i should get the Uprev Tune first...
Old Jul 16, 2012 | 07:59 AM
R350Zz33's Avatar
R350Zz33
Tune then spray btw I will be selling a zex bottle heater and 1/2 full bottle and a remote bottle opener soon
Old Jul 16, 2012 | 08:35 AM
thisishk350's Avatar
thisishk350
Uprev tune for sure, even if you do plan on spraying. NOS + no tune = boom
Old Jul 16, 2012 | 11:48 AM
Suwaidi's Avatar
Suwaidi
If you're set on getting a nitrous kit in the future, save up for both. If you get tuned first, you'll have to pay for a retune later when you get your kit installed, which will be based on an hourly rate. Might as well get it all done at once.
Old Jul 16, 2012 | 12:07 PM
doshoru's Avatar
doshoru
It sounds like you need to do a lot more reading about nitrous.
Old Jul 16, 2012 | 08:03 PM
!Z!'s Avatar
!Z!
I know alot about nitrous i was told i can run a 75shot no tune. And that basically the highest i was gonna go no more then 100....
Old Jul 16, 2012 | 08:58 PM
k6750gsxr's Avatar
k6750gsxr
I am not suggesting nitrous unless you know how to use it. Get some good na trap times before you venture into spray territory...
with that said i have done a few nitrous cars with out a tune. a few things to consider when setting up.
1. run a colder plug if you want to run 75 plus shot.
2. go to a dealer and have them pull 1 or 2 degrees of timing.
I suggest a zex kit or something with a wot sensor so there is not accidents. Also, if you get a warmer get a pressure release valve atleast just in case you forget to turn it off. Nothing worse than coming out to a hatchless z.
Old Jul 17, 2012 | 10:45 AM
rtiid22's Avatar
rtiid22
You should get nitrous first along with colder plugs, install it at your leisure, then in 2 weeks get the uprev tune and have your tuner give you both an n/a tune and a nitrous tune.. Done.
Old Jul 27, 2012 | 07:22 AM
twistiert's Avatar
twistiert
Definitely do nitrous kit first and then tune. No sense on tuning before you put the power adder on
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
