Oil Pump failing?
-This whole thing started when i put 10w-30 in by recommendation from a fellow Z owner. That whens i noticed higher than normal PSI. Next day i put 5w-30 instead and same PSI readings. 10w-30 and 5w-30 were same readings that was my belief towards PRV being stuck. Ive done 2 oil changes, and an engine flush so far. Nothing changed. Havent had a chance to record oil temp vs PSI.
-I found a really nice shop near by who is going to check it out for me tomorrow if its good then getting a tune if not then repair .
Basically the guy out in cali did a call on what was wrong. The place near me said it was my sensor. So i replaced that. PSI is now 15 idle 40-45 highway and 90 red line. Now i can start my tuning and build.
Rexrodriguez
Dec 23, 2015 09:20 AM
