Timing jumped, help!
Old Jan 10, 2020 | 02:14 PM
Jdm.350z's Avatar
Jdm.350z
Default Timing jumped, help!
I unbolted the primary chain tensioner so I could get to a bolt and the timing jumped on bank one. Can I get the timing close so I could put it at tdc? I took a picture before it jumped.
Old Jan 11, 2020 | 05:34 AM
jhc's Avatar
jhc
General & Tech Moderator
Only you can answer your question "Can you..."
Once I was faced with a bad head gasket on an overhead cam engine with a turbo. I got quotes and said, "Eff this" and did it in my garage after very extensive research. If you're on a budget research exactly what it will take to correct this (and not make it worse). If you estimate you can do it after you thoroughly understand it, go for it. Otherwise start saving for professional help.
Good Luck!
Old Sep 26, 2023 | 07:13 AM
iIcecreamm's Avatar
iIcecreamm
Any update?
Old Sep 26, 2023 | 11:28 AM
travlee's Avatar
travlee
Master
Originally Posted by iIcecreamm
Any update?
he hasnt logged in since he made the post
Old Feb 29, 2024 | 06:22 PM
Painterguy39's Avatar
Painterguy39
Anyone have any solution to this?
I had both banks "jump" while doing oil gallery gaskets
StephenM57
Jun 2, 2025 09:39 PM
StephenM57
Sep 4, 2023 12:51 PM
JoBAGZ
Dec 8, 2013 08:30 AM
specialist
Aug 25, 2009 01:57 PM
sik350
Apr 5, 2009 04:55 AM
