Mods for reliability
Old Nov 19, 2025 | 09:11 AM
Jonasjamieson's Avatar
Jonasjamieson
Default Mods for reliability
Just got a 2003 350z touring with the vq came with stillen headers, valve body and exhaust and it’s got a racing pulley what are some mods that overall will make it more reliable
Old Nov 19, 2025 | 12:59 PM
travlee's Avatar
travlee
Master
Driver mod so you dont end up in a ditch on Dugan day, which ia right around the corner
Old Nov 19, 2025 | 01:44 PM
iideadeyeii's Avatar
iideadeyeii
Taking off the front and rear bumper supports will reduce weight and therefor decreasing the load on the engine. Increasing reliability
Old Nov 19, 2025 | 02:53 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Start by upgrading the fluids in your Z with products that meet or exceed factory specs. Replace old brake fluid with DOT 4 brake fluid with a higher dry boiling point should be a good example. That same brake fluid can be used in the clutch slave and master to make your clutch more reliable. The list goes on and you can read multiple threads on here to determine the best fluid or lubricant to improve reliablity.
35X
Sep 9, 2007 05:12 PM
Nismo 350z
Oct 5, 2005 04:55 PM
skyl1ne6mt
Dec 27, 2004 02:05 PM
amallari
Nov 13, 2003 11:30 AM
