anyone lowered a 350Z with VDC?
The dealer... has to be one of the worst sources of information... strange no?
Eibachs, about 1" lower all around on a Touring with VDC. 20K miles. No problem as far as I know...
Originally posted by ghost11
some retard at the dealership said putting lowereing springs on my 350 would affect my VDC, has anyone done this?any info would be great
ghost11...
The answer to your question is maybe. I think most (as evidenced above) have had no VDC problems with dropping their car.
In my case, I did have a problem. We used the B+G springs and let them settle for about a month before getting an alignment. during that month, my VDC wigged out... Often, i would get the slip light and the VDC Off light to come on at the same time and stay on until I recranked the car. Not always, but often.
Wound up getting my alignment done at Nissan and found that the lowering threw off something in the VDC causing it to trip a code. if we would have reset the code without aligning, it would have just happened again. Since I was already there for alignment, we did that, then reset the code and I haven't had a problem since.
Bottomline... if you do have a problem, it is likely to be something easily rectified.
I had to roll my 1/4s to not scrub, but my fronts were fine. Of course, I'm running 275/40/18s in the back. Wish I could tell you my offset, but I don't remember. Seems like I have offsets of +25 and +12 or something like that, but I don't remember which front and which is back.
HoneyBadgerRy
Sep 21, 2015 03:25 PM
