will 295/35 fit w/nismo 10.5 with 15mm offset?
Old Nov 27, 2004 | 12:25 AM
sentry65's Avatar
sentry65
the burninator
Default will 295/35 fit w/nismo 10.5 with 15mm offset?
I'm thinking about putting the nismo 9.5's on the front with 265/35's
and 295/35 on the back with 10.5. Both being 18in
Possible? rubbing issues?
I'm also thinking about getting the TEIN flex suspension - can the car be lowered at all with those tires/wheels?
I tried searching, but didn't come across anyone with that setup
Old Nov 27, 2004 | 02:23 AM
manofsteele2003's Avatar
manofsteele2003
No one has that set up because NISMO doesn't make those rims with a 10.5 width. They are 8.5 front and 9.5 rear, that's all that's available.
Old Nov 27, 2004 | 07:08 AM
daytona350z's Avatar
daytona350z
yea you are right, nismo doesnt make them. Rays wheels makes them...and yes they are avaialble in 10.5 with a +15, but i would imagine some fender rolling and some agressive camber wll be needed to fit. jason@performance runs 10.5 with a +30mm offset.
i dunno though, you will be the first t try.
http://www.rayswheels.co.jp/cgi-bin/...?modelName=GT4
Old Nov 27, 2004 | 07:39 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you'll be rolling fenders (nd maybe doing metal work) to run a 10.5 +15
Old Nov 27, 2004 | 09:45 AM
sentry65's Avatar
sentry65
the burninator
what if I did 285's with the 10.5 - that's probably not enough though
what if I did 285's with 9.5's in the rear?
what about those wheel spacer things?
Old Nov 27, 2004 | 09:50 AM
Driven's Avatar
Driven
I'm running Ray's GramLights 9.5 front and 10.5 rears with the tire sizes you originally posted. I'm running 25+ offsets and think they are perfect...no fender roll necessary and even put drop of 3/4".
Old Nov 27, 2004 | 09:58 AM
sentry65's Avatar
sentry65
the burninator
awesome thanks! do you happen to have a pic of your car anywhere?
I'm wanting to get as wide as I can get and don't really want to reinvent the wheel with offsets etc
I've been toying with the idea of putting 19's in the rear and 18's up front, the nismos have +15, +30, and +38 offsets.
Their 18's with 10.5 only have an offset of 15 as an option as far as I can find.
What about the fronts? Can you do an offset of 15 up front with the 9.5's and still be ok or should you go +30 all the way around?
Old Nov 27, 2004 | 01:57 PM
03Z33's Avatar
03Z33
The 18x10.5 et 15 Nismo wheel fits no problem on a stock height car with 275/40/18 tires. I don't have pics, but that is what Eugene from SP-Engineering runs with -1.5 deg. camber and has no rubbing.
When you lower the car clearance should improve... providing you don't dial out way too much camber. The 295/35/18 should fit well too, if anything just be prepared to roll the fender slightly. Shouldn't be needed though.
He also runs 18x9.5 et 12 up front and it does not rub, but in my oppinion is a little too wide unless you lower the car.
BTW it is a sick looking wheel!
Old Nov 27, 2004 | 05:33 PM
Driven's Avatar
Driven
My pics are saved on my home computer...and unfortunately it is currently down. However, a buddy is coming over Sunday eve to try and save the day...pm me your personal email address and if/when I can get my home computer up and running I'd be happy to send you some pics. I did a great deal of research prior to special ordering my Ray's with that offset...unfortunately...offsets are pretty much a personal taste thing. If you run the same tire setup as myself....I can tell you no one has ever said they look too tucked...nor have they said they look too getto (is that politically correct?) Anyway...send me your email and I'll do what I can for ya.
Old Nov 27, 2004 | 06:03 PM
sentry65's Avatar
sentry65
the burninator
your PM box is full right now
i'll try again later
Old Nov 27, 2004 | 10:48 PM
Driven's Avatar
Driven
My box isn't supposedly full...at least it's not telling "me" it's full. I PM'd you with my email address...when I get my computer up and running and have yours...I'll see if I can't get you few pics.
Old Nov 28, 2004 | 11:41 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
I've run 285/30 on a 10.5 +22 in the back before (even on the racetrack) with no problems!
295/30 may be a better choice.
Old Nov 29, 2004 | 05:26 AM
Jun's Avatar
Jun
295 fits on a 10.5 width rim. You can even fit 315 if you wanted to, just as JDMZ33, he has 19x10.5 with 315 on the back.
Old Nov 29, 2004 | 06:08 AM
Z04's Avatar
Z04
i think you mean a different rim since it was said earlier that NISMO does not have that rim size at all. the LMGT-4 NISMO rims are 18x8.5 front, 18x9.5 rear.
Old Nov 29, 2004 | 06:11 AM
ttsupra94's Avatar
ttsupra94
I'm not sure what a 15 offset looks like. My wheels have 275/35 19 and sit flush with the fendor pretty much. I'm also dropped with tein s techs and i'm pretty sure I can easily fit a 295/35 19 on my 10.5 rear with no rolling or anything required. I would think the 295/35 18 would be no problem.
Old Nov 29, 2004 | 06:19 AM
daytona350z
they do make lmgt-4's in 18x10.5, no one sells them here tho, you would have to special order them.
click on my like i provided earlier.
Old Nov 29, 2004 | 06:47 AM
Z04's Avatar
Z04
i stand corrected. thanks for that info
Old Nov 29, 2004 | 06:49 AM
daytona350z
no problemo
Old Nov 29, 2004 | 12:19 PM
RaySur350GT's Avatar
RaySur350GT
Well, with a +15 offset and tires wider than 275, you will definately need to roll your fenders plus have some camber to have it fit.
Right now I have +17 in the rear with 275/35/19s on a 10.5 rim and I needed to have my fenders rolled. My rim flushes EXACTLY to the rear fender. Now with a 10.5 with +15 offset riding on 285+ tires, its gonna stick out of the fender wall.
Old Nov 29, 2004 | 01:13 PM
03Z33's Avatar
03Z33
18" wheels will allow for a little more room... also the Z rear fenders will fit a slightly more aggressive setup than the G35 Coupe.
