just got 19's on. mad gap. help.
Old Nov 27, 2004 | 10:11 AM
nureulsaranghae's Avatar
nureulsaranghae
Default just got 19's on. mad gap. help.
Hi, I just put these on the car, but the gap in the rear is amazing...i can fit my fist across the gap. my car has 15k miles on it. the rear tires are 275/30/19. But on the last owners stock suspension car, it wasn't like this at all....what is wrong with my car? how much help of getting 275/35/19's help me?
here's the pic on my car.
and here's the pic with last owner's car.
wtf?
help me guys.
thanks
John.
Old Nov 27, 2004 | 10:18 AM
AmateuRN's Avatar
AmateuRN
Well...now I'm scared cuzz I'm only gettin' 18's with a 40 series tire.....
Old Nov 27, 2004 | 10:27 AM
nureulsaranghae
here's another to compare
His.
Mine.
wtf? help.
John.
Old Nov 27, 2004 | 10:33 AM
z33saru's Avatar
z33saru
they both look pretty identical to me.
i think the different lighting is giving off the illusion that his has less of a gap.
if u dont want it to look like a 4x4, u should lower it.
Old Nov 27, 2004 | 11:05 AM
nureulsaranghae
haha yea, but The rear tires are bald and needs to be replaced anyways. so i was thinking....how would 275 40 19 fit in the rear? since 275/35/19 only improves the gap by .25inch. will 275 40 19 fit if not lowered? what if it was lowered? the offsets on axis supermesh are 40mm in the rear.
let me know guys....this is so frustrating that i wanna put my stocks back on.
thanks
John.
Old Nov 27, 2004 | 11:27 AM
roark's Avatar
roark
Yes, 275/40-19s will fit fine. You may have to trim the threaded stud in the LH well for the Track model diffusers. Just leave about 1/4" of thread in case you want to put those on.
Old Nov 27, 2004 | 11:37 AM
nureulsaranghae
I just want my car to be having same gap as when i had 17inch stock wheels.... I searched around a lot on every size and now i am more educated hehe...
So if i wanna get the same wheel gap as my 17inch stockies, go with 275/35/19 huh? or would there be still more gap in the rear?
let me know guys.
thanks
John.
Old Nov 27, 2004 | 11:43 AM
1nate7's Avatar
1nate7
IMO to make it look right you need to go to 275/35/19 in the rear AND give it a small drop, something like RS*R or Tein S-Tech springs. If you have the correct size of 245/35/19 on the front there would be a 2" overall diameter difference front to rear with a 275/40/19. If you want slightly more sidewall I would try a 285/35/19 first.
Old Nov 27, 2004 | 12:24 PM
nureulsaranghae
yes, i do have 245/35/19 on the front.
so try 275/35/19 first and drop it in the future eh?
thanks guys! you guys are helpful! unlike other car forums just smacking you down. lets keep up the good and kind community.
thanks again.
John.
Old Nov 27, 2004 | 01:12 PM
grifferjr's Avatar
grifferjr
thanks again.
John.
i know you already have gotten some good advice but here is my set up. 245/35/19 front and 255/40/19 rear. has a lot of stagger. over an inch taller in the rear but as far as filling the wheel wells it looks about the same as stock if not a bit more filled up in the rear. no drop or anything.
Old Nov 27, 2004 | 01:24 PM
nureulsaranghae
well here's the final question then! about 245/35/19 front and 255/40/19 rear, is this set up better or 245/35/19 front and 275/35/19 rear? how about look wise on stock suspension/gap,performance,handling?
sorry for bothering you all.
thanks
John.
Old Nov 27, 2004 | 02:25 PM
1nate7's Avatar
1nate7
If your wheels are wide enough to handle a 275 in the rear then I don't see any advantage in using a 255. There is a reason the 245/35-275/35 setup is so popular. It keeps the stock overall diameter stagger (rears 1" bigger than the fronts) and the width stagger as well. You could certainly run a 255/40/19 on a 9"- 9.5" wheel if you wish, but I prefer wider tires in back - it gives it a more aggressive look. Everyone has there personal preference, but IMO there is no way around the "4 x 4" look on 19's without a drop.
Old Nov 27, 2004 | 03:11 PM
grifferjr's Avatar
grifferjr
if i remember right the main reason why i went 255 on rear versus the 275 was because of tire/rubber availability and the brand of tires. i have falkens and i think there was an availability issue with the 275 and getting the right stagger. i think toyo makes the T1-s in the right 275 size but my package was for falkens. i could be mistaken cause i did this over a summer ago and the memory is a little foggy by now.
what i can say is vertical heigth it filled the wheel wells out just right. but as far as width the 275's would be best cause my 255's were a little sucked in and i just threw an 8mm spacer in to bring it out to the fender. this can also be addressed with a more offset rim.
Old Nov 27, 2004 | 03:50 PM
z33saru's Avatar
z33saru
what size are your wheels?
Old Nov 27, 2004 | 04:16 PM
nureulsaranghae
9.5 in the rear.
Okay guys. i will stick with 275/35's. well here's another question. yes, again. haha
Are bridgestone Potenzas RE040 good in 275/35's? or dunlop 9000's?
thanks.
John.
Old Nov 27, 2004 | 04:18 PM
z33saru's Avatar
z33saru
bridgestone s03 would be good tires.
Old Nov 27, 2004 | 04:21 PM
nureulsaranghae
oh and lastly, i was always wondering what 275/35WR19
275/35YR19
all those ZR19,WR19,YR19 and those meant.
does it matter? ifso, which one do i need? lol.
thanks
John.
Old Nov 27, 2004 | 04:26 PM
nureulsaranghae
is 275 35 R 19 fine? cuz that's the one im getting.
thanks
John.
Old Nov 27, 2004 | 06:08 PM
z33saru's Avatar
z33saru
yes, 275/35R19 is correct.
the "R" is for radial.
the other letters, "Z", "W", "R", are just the speed rating of the tire i believe.
Old Nov 27, 2004 | 10:59 PM
nureulsaranghae
Thanks Z33saru for the help.
I just bought a pair of slightely used 275/35/19 Bridgestone Potenza RE050(5000miles) for $200 shipped.
Did i make a right choice or did I get ripped off?
thanks
John
