Offset once again!
Old Dec 15, 2004 | 06:31 AM
ttsupra94's Avatar
ttsupra94
F1 motorsport got back with me and said i have 19x9 26et and 19x10.5 26et and nowhere close to rubbing anything.
Old Dec 15, 2004 | 06:15 PM
nicolaycastro's Avatar
nicolaycastro
thanks, that was my main problem, the once i was getting where 10.5 with an offset of 19, know im going with 10 and offset of 19 so the conversion should give me a simmilar offset as if i had 10.5 with offset of 24. i guess i should be fine.
Still no wheels
Old Dec 15, 2004 | 06:34 PM
tonio's Avatar
tonio
I had the same wheels with the same offset you are getting, trust me there will be plenty of room even if you go with the S-techs. Stock suspension I could fit more then two fingers between the wheel and the fender on the rears..three fingers on the front, to the point where it needed a drop to look right.
Old Dec 16, 2004 | 02:59 PM
nicolaycastro
thanks, the problem that i was seeing was getting on the back 10.5 with 19 offset on the back, and tghen dropping it. Jason told me that with that setup and dropped it would rub (not all the time though). So ive decided to go with 10 and 19 offset, therefore the wheel does notg come out that far out of matching with the fender, that would have cause me a problem if i dropped my car.
Anyways thatks for the input.
So TONIO how does the gap look now?
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
