Just ordered Volks!
Old Dec 10, 2004 | 11:25 AM
bwzabodyn's Avatar
bwzabodyn
Default Just ordered Volks!
I just placed my order with F1 for a set of Volks - they should be pretty unique - I think they are going to be the first setup with these particular sizes/offsets...
19x9.5 +29 SF-Winnings Mercury Silver - front
19x10.5 +29 SF-Winnings Mercury Silver - rear
255/35/19 BFGoodrich G-Force T/A KDW2 - front
285/35/19 BFGoodrich G-Force T/A KDW2 - rear
Should look pretty sick! Too bad I'm going to have to wait 60+ days...
Old Dec 10, 2004 | 11:40 AM
RCKTDAWG's Avatar
RCKTDAWG
Post pictures when installed. I ordered the same tires for LE37T +22s. Hopefully they won't stick out. It's hard to get a direct answer about if the tires will stick out. I actually called Shawn at SGP Racing (very nice guy), he's the one with the G35C with 585 RW horse power. He told me they would fit. We will see in a few days. If not I will have to re-groupe.
Old Dec 10, 2004 | 12:22 PM
Neadmiken's Avatar
Neadmiken
very nice choice man
Old Dec 10, 2004 | 02:06 PM
bwzabodyn's Avatar
bwzabodyn
I hope so - I've done research and did a lot pondering before I finally plopped down the deposit for these bad-boys - Don't worry, pictures will be coming out the wazoo when they're mounted...
Old Dec 10, 2004 | 02:26 PM
tonio's Avatar
tonio
You didn't want to go with a more aggressive offset?
Old Dec 10, 2004 | 07:35 PM
Dragonstyle's Avatar
Dragonstyle
Can't wait to see the pics....you should be having some fat lips!.....
Old Dec 10, 2004 | 08:09 PM
fasta's Avatar
fasta
who did you order them from?
Old Dec 12, 2004 | 04:35 AM
ssc's Avatar
ssc
are you planning on using your tire pressor sensors? how will you mount those...cuz they dont fit on sf-winnings
Old Dec 13, 2004 | 11:30 AM
bwzabodyn's Avatar
bwzabodyn
2003 G35 Coupe - so no tire pressure sensors...
I ordered them from Chris at F1 motorsports - they had to be special ordered, so they should be coming in around February...
I didn't want to go with more aggressive offsets because I want to be able to have more freedom when it comes to tire size choices - I do not want to have to do any kind of fender work and I don't really like that look anyways (where the tire has to have 5 degrees of negative camber to fit within the wheelwell) - if I've done my homework correct, this setup should be exactly what I'm looking for (fat lips all the way around, wider tires than what most are running, and no fenderwork after a 1" drop).. I guess the pics will tell the story when it's all said and done...
Old Dec 13, 2004 | 01:13 PM
ttsupra94's Avatar
ttsupra94
I might switch over to those tires. That sucks for waiting that long. I got my wheels from F1 too but I only waited about a week! But if you want something custom, i guess you can't expect to get it right away.
Old Dec 13, 2004 | 02:30 PM
bobS's Avatar
bobS
WOw 10.5 fits? How wide could one go with the correct offsets? I'm set on going 19 x 9.5 in the rear but i was worried about rubbing with that. I want a big lip so maybe i should go 10?
Sucks u have to wait that long man...hopefully when i order my rims i won't have to wait that long
Old Dec 14, 2004 | 03:24 AM
ttsupra94's Avatar
ttsupra94
bobs- it depends on the offset of the wheel. there are a lot of people running 10.5 but some have had to modify/roll the fender for them to fit. I have 10.5 and have not needed any modifications to the fender. I would get at least 10's in the rear.
Old Dec 14, 2004 | 04:39 PM
Rayden2001's Avatar
Rayden2001
10.5...I have 11" wide with a rolled fender.
Old Dec 14, 2004 | 04:44 PM
kevinapex's Avatar
kevinapex
I ordered volks from 350z online, SLOW BOAT FROM JAPAN!!! told me it would be 2 months it's been 5 months, still no volks! Maby next week. good luck!
Old Dec 15, 2004 | 11:34 AM
bwzabodyn's Avatar
bwzabodyn
man... don't tell me that... I'm already counting the days...
btw, what wheels did you order?
Old Dec 15, 2004 | 03:05 PM
jester7500's Avatar
jester7500
I'm curious as well to know what wheels you ordered.
Old Dec 15, 2004 | 03:25 PM
tonio's Avatar
tonio
I special ordered the exact same wheels you did bwz..ordered them back in september and I should have them by friday.
ablaine
Nov 29, 2016 10:13 AM
