19 inch rim by width and maximum offset W/O rolling the fender?
Old Dec 15, 2004 | 03:18 AM
ttsupra94's Avatar
ttsupra94
I have a 19x10.5 with a 26 offset and nowhere close to rubbing and i'm using tein s techs too. 275/35/19. I'm going to get a bigger tire i think
Old Dec 15, 2004 | 05:38 AM
1G-350Z's Avatar
1G-350Z
Originally posted by tylerdurden
Hey Rob! It's Chris with the Redline. In the end it's all about the chicks!
What's going on Chris!
How are the new Nismo's, any Rubbing issues with 18x10.5" 295/35 Tire? (We cut his rear fenders too) For this discussion do you remember the offset? And did they finally fit over your Brembo's (front)?
Sorry about the mutiple questions...
Another benafit is that on a 10.5" rim and offset that will pull the wheels out... Will give you room for that BIG Brake Kit one might want.
Old Dec 15, 2004 | 05:52 AM
1G-350Z's Avatar
1G-350Z
Exactly.... "2quick2fast" jut put up a very informative chart, that clearly shows why I had to cut vs. why you didn't... I'm almost positive I'm have +17 (10.5) in the rear and +19(9.5) in the front
Too cold outside to clean the inside of the barrel and check
With a 26 offset you should be able to get a 285. 295 might rub...
Old Dec 15, 2004 | 06:20 AM
ttsupra94's Avatar
ttsupra94
i'm pretty sure i have plenty of clearance for even bigger tires. it depends on the sidewall ratio too. I think 295/35 is the largest i could go, but i've also looked at 305/30 and 315/30 which are actually shorter (overall diameter) than the 275/35 that i'm currently running. I will have to look at it more to figure out what i can run. I dont think i have too much room to change tires in the front though, i might switch to a 255/35 but that is it.
Old Dec 17, 2004 | 06:24 PM
tylerdurden's Avatar
tylerdurden
I was going to run the 10.5 Enkei wheel +30 offset with a 295 tire. After we cut the fenders they fit perfectly. Unfortunately the fronts didn't clear my Brembos. I decided to go with the Nismo wheels with 275 rear tire. I'm on a pretty low drop, even with the 275's it's close. No issues though with rubbing.
Old Dec 20, 2004 | 11:45 AM
lex11877's Avatar
lex11877
I know a balck 350Z down here in FL that is running a 285/35/19 without rolling fender . It also depends what tire brand you go with also.
Old Dec 20, 2004 | 12:02 PM
1G-350Z's Avatar
1G-350Z
Brand is not that big off an issue.... Offset, Width, and tire size is...
Old Dec 24, 2004 | 05:33 PM
SooMighty's Avatar
SooMighty
are the Toyo T1's good for a 10.5 rear? Ive heard mostly that it looks perfect and not much stretched. Will there be any problems with 10.5 width running on the 275's? I want to keep my rims in good condition.
Old Dec 25, 2004 | 01:15 PM
symbolic350's Avatar
symbolic350
im using a 19x9 19x11 witha 315 tire in rear no rubbing issues
and its lowered about 1.5 no problems i rolled fenders in a week later cause a friend has the machine so i took advantage of it
but no problems what so ever!
Old Dec 26, 2004 | 09:34 AM
___DJK___'s Avatar
___DJK___
I wouldnt envision a lot of rubbing when you are rolling on a 25% profile tire!
Old Jan 6, 2005 | 08:27 PM
StefanZ's Avatar
StefanZ
Default Rolling fenders
Can someone tell me for sure if rolling increases the chances of corrosion of the fender pinchwelds? I'd assume it does....
Old Jan 6, 2005 | 10:03 PM
biscotti's Avatar
biscotti
Default Re: Rolling fenders
Yes, I have also heard that this is the risk you run when rolling fenders as this often will crack the paint. Given the choice cutting is preferable to rolling.
Old Jan 7, 2005 | 08:19 AM
1G-350Z's Avatar
1G-350Z
I had my fenders cut and put globs of factory paint on the exposed edge. I inspected the scrap metal, and it looked liked aluminum... And it bend like aluminum. I would verify that with nissan parts or a body shop.
Obadabot
Jun 18, 2023 11:31 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
