psi in the blizzacks
Old Dec 15, 2004 | 05:27 PM
grifferjr's Avatar
grifferjr
Default psi in the blizzacks
who knows what the best psi is in blizzacks. ws-50 17 inch. i am sure to get best performance a winter tire like this is different than our oem psi of 35psi. i am think lower cause that would allow better grip, but i am often wrong with these things. thats why i am asking.
Old Dec 15, 2004 | 05:48 PM
julian's Avatar
julian
should be about the same pressure as regular tires, even more so if they're the same size. if you run them too low you'll have bad performance at higher speeds. a snow tire should have enough grip for regular driving in the winter... no need to "look" for more grip.
Old Dec 16, 2004 | 10:45 AM
roydiculous's Avatar
roydiculous
yes, do 35psi COLD.
Old Dec 16, 2004 | 01:16 PM
Luke@tirerack's Avatar
Luke@tirerack
35 front and rear
Old Dec 16, 2004 | 03:01 PM
grifferjr's Avatar
grifferjr
Originally posted by Luke@tirerack
35 front and rear
great guys, thanks for the reply. the only reason why i asked was because the max PSI rating was considerably less than for the regular tires. but then again that should not affect or rather represent what the optimal running PSI is.
so with that said, BRING ON THE MFing SNOW!!!!!!!!!
apex locator
Jul 23, 2021 02:27 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
