Same-width wheels all around?
Old Dec 23, 2004 | 11:27 PM
Z BOY's Avatar
Z BOY
Default Same-width wheels all around?
What are the advantages and disadvantages? How is handling affected?
Old Dec 23, 2004 | 11:41 PM
DLin05's Avatar
DLin05
do you mean width?
Old Dec 23, 2004 | 11:44 PM
Z BOY's Avatar
Z BOY
yes
Old Dec 24, 2004 | 05:29 AM
ALong's Avatar
ALong
Same size wheels/tires front/rear reduces the understeer.
Old Dec 24, 2004 | 07:11 AM
westpak's Avatar
westpak
SFZCC
It will reduce understeer and you rear will want to swing out a little easier so you would have to get used to it before you go out and drive like you were used to.
Old Dec 24, 2004 | 08:44 AM
twenzel's Avatar
twenzel
has anyone tried to mount the rear rays track wheels on the front of the Z?
I dont think there would be a problem with it since the R34 uses the same offsets and wheels sizes from the factory on all four corners as the Z33's rear wheels. And I've seen a Z33 with R34 wheels and it looked perfect.
I don't really see the point in running a smaller tire up front unless drag racing was involved.
Old Dec 24, 2004 | 10:26 AM
Z BOY's Avatar
Z BOY
would it make my tires last longer since i would be able to rotate them?
does it look funky?
tonywenzel, pls don't jack my thread.
Old Dec 24, 2004 | 10:51 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Well don't forget that the R34 (GTR) is all wheel drive, so the rims would be the same width all around.
Old Dec 24, 2004 | 11:16 AM
twenzel's Avatar
twenzel
:-| sorry no intention of hijacking. I have the same questions...
Cause, really I don't see any disadvantages besides maybe the weight. But thats minimal in difference.
The advantages, are more grip up front which means less understeer. which is perfect if you ask me.
Anyone else have any first hand experience with running same tire sizes all around?
Old Dec 24, 2004 | 12:34 PM
lowrider's Avatar
lowrider
Z Boy
What the heck is this thread all about
It looks like you have the same width wheels all around now, since you have the stock cast 18s. Do you mean same width and height or tire
Just not sure what you're asking here.
The same width and tire size would not be a good idea. It would kill the stagger. But a 245/40/18 front and 245/45/18 rear tire setup would work. It would maintain the stagger, and reduce some of the understeer. The cross section (width of the tire) would stay the same, but the aspect ratio front to rear would be different.
Lou
Old Dec 24, 2004 | 07:20 PM
Z BOY's Avatar
Z BOY
Lou,
i have the stock setup, which is 1" wider in the back, but if i had the same width all around, i could rotate the tires, hopefully prolonging the life of the tires, as i have already had one set of fronts replaced due to feathering, but now the extended alignment warranty has expired, and i'm trying to find my own practical solution to my car's tendency to cause feathering of the front tires; as a g owner, you wouldn't know about that, which is why you don't understand this thread, but Z owners with feathering problems would understand me.
Matt
Old Dec 24, 2004 | 07:37 PM
westpak's Avatar
westpak
SFZCC
Your stock 18's are 8" all around, it is your tires that are different in width, the track model has 8 and 8.5 rims. If you put same width all around you can rotate, you will have less understeer which if you do not drive on the track you will probably not notice much, but it might mess with the VDC.
Old Dec 24, 2004 | 07:43 PM
Z BOY's Avatar
Z BOY
thanx, westpac, i didn't know the rims were same size. so i guess the better question is
has anyone else had experience with same size TIRES all around?
did it mess with vdc or cause any problems?
Old Dec 25, 2004 | 07:52 AM
twenzel's Avatar
twenzel
From previous testimonials on this board, yes it will trip the VDC. If the ecu doesnt see the different wheels speed from the stagger the VDC will kick in. So if you had all same tires sizes you will have to constantly drive with VDC off.
Which, if you ask me, really isnt that big of a deal since i do that already anyway.
Old Dec 25, 2004 | 10:06 PM
Z BOY's Avatar
Z BOY
thanx, tw. i drive with the vdc off as well, except in wet weather. as i understand it, the vdc helps with traction in wet weather. if i run same-size tires all around and drive with the vdc ON during wet weather, what will happen?
Old Dec 25, 2004 | 10:17 PM
westpak's Avatar
westpak
SFZCC
Your light will probably come and the engine cut out, that is what happened with my TCS when the sensor was bad, so maybe similar symptoms.
Old Dec 25, 2004 | 10:23 PM
Z BOY's Avatar
Z BOY
oh shzit, that's freakin dangerous! Gonna have to call Nissan on this one.
Old Dec 25, 2004 | 10:28 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
I have 245/40/18 all the way around with 18X8 wheels. Just got my tires rotated
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
