My new Silverstone Z with 19’’ Axis Hiro wheels (56K warning)
Old Jan 6, 2005 | 01:17 PM
dewuser's Avatar
dewuser
Originally posted by Neadmiken
nice looking wheels
I almost forgot to Thank MIKE from Northeast Aftermarket for the best price on my tires!
Mike was a big hand in assisting me! I highly recommend him.
Thanks again
Old Jan 6, 2005 | 01:32 PM
dewuser's Avatar
dewuser
Originally posted by mgl
just buy dave's (whatever) springs and get an alignment done after installing them.
for installation, try contacting Chad (KarmaMag) and have them installed at his shop.
I think his springs are about 1'' drop, would that negatively affect the camber?
Old Jan 6, 2005 | 01:37 PM
dewuser's Avatar
dewuser
Originally posted by Bertg
Tein S-Tech springs drop the car about .7" all the way around. Ride quality is a little stiffer, but still comfortable for everyday driving. You'll still need an alignment after the springs settle.
A .7'' drop sounds good! Did you have any special camber adjustments?
I read you sign and I'm kinda curious about your ride, could you post a picture of your Z with the Tein S-Tech springs?
Old Jan 6, 2005 | 01:39 PM
dewuser's Avatar
dewuser
Originally posted by zland
If warranty and alignment are issues, NISMO S suspension drop is .75" all 4 corners, ride is good, warranty is best option other than stock.
Jeff Zland
The NISMO S suspension only comes as a whole package or can you purchase just the springs?
Old Jan 6, 2005 | 01:58 PM
JimRHIT's Avatar
JimRHIT
Hotchkis springs. 0.7" drop and the same ride as stock
I went from stock to Eibach (liked the rigde height, hated the comfort), so I switched back to stock for 5000 miles
I then added my racing harts and wanted to lower the car again, so I tried Hotchkis (installed by protocav here in SD)
It settled to a 0.7" drop and rides the same as stock to me ... with a lot less bounce.
Old Jan 6, 2005 | 02:19 PM
dewuser's Avatar
dewuser
That sounds just like what I'm looking for!
Quick question:
When you said "Eibach (liked the rigde height, hated the comfort)"
#1 - Did you mean, it was too cushy or too harsh (bouncy)?
Now with the Hotchkis springs you say they feel better than stock; which sounds great!
#2 - But did it affect your camber too much?
#3 - Do you have any links to pictures of your ride?
Old Jan 6, 2005 | 02:29 PM
JimRHIT's Avatar
JimRHIT
It looked nice, but the camber was uncorrectable. It rode terribly rough for me, and it was "floaty" feeling in a turn ...kind of weird, but it was not very linear feeling
My camber was correctable
si
I never pass up an opportunity to post pics
Old Jan 6, 2005 | 03:01 PM
dewuser's Avatar
dewuser
First off, your Z looks AMAZING!!!
And that looks to be the PERFECT drop; because I can't stand slammed cars.
So your camber was correctable with just adjustments during the alignment, is that correct?
Did you have to roll your fenders?
And what about rubbing? (Although that has more to do with your wheel offset)
Old Jan 6, 2005 | 05:05 PM
jreiter's Avatar
jreiter
Aren't the Eibachs progressive rate? That could explain why they didn't feel linear.
Old Jan 6, 2005 | 05:09 PM
jreiter's Avatar
jreiter
That makes sense. The ride on the Hotchkis springs should be very similar to stock since they are almost the exact same spring rates. Other than lowering the height, the only thing Hotchkis really did was soften up the rear springs a bit to account for the underdamped stock shocks. This fixes the rear bounce the Z seems to have a problem with.
Old Jan 7, 2005 | 12:57 PM
whatever's Avatar
whatever
Veteran
I felt the Eibachs was a little softer than the stocks which improves the ride from stock. It was a better match for the 2003 shocks.
Here is some pics before I put on the coilovers. I didn't have to roll the fender for 245/35/19 & 285/30/19. & zero rub!!
I was able to get the rear camber within spec.
Old Mar 26, 2007 | 04:26 PM
xNeo's Avatar
xNeo
I was looking into this same setup, do you have any other pics...mainly of the 10.5 and the 3" lip? From the back if you could! PLEASE?
Obadabot
Jun 18, 2023 11:31 PM
35reilly
Sep 28, 2015 07:42 AM
