Correct tire size for 20" wheels?
Old Jan 15, 2005 | 08:38 PM
solidsnake's Avatar
solidsnake
Default Correct tire size for 20" wheels?
Ok I got the 20" inch axis se7en mods..20x9 front and 20x10 rear. Ive been told by some guys on here that the correct size is 255/30/20 for the front and 285/30/20 for rear. Is this correct? Will I have a problem with these sizes? I want to know for sure before I spend 1300 bucks on tires alone. Please help..
Old Jan 15, 2005 | 11:07 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
I have the same size rims and I was told to get:
255/35/20 F
285/30/20 R
What tires are you planning to get? I wanted Toyo but they don't make 285/30/20 (Widest is 275) so I think I'll be going with the BF Goodrich KDW2 or Michelin PS2.
Old Jan 16, 2005 | 04:38 PM
JDMautoworks's Avatar
JDMautoworks
wassup James........its Mike (blue IS300)
the tires you mentioned are the preferred size.......i would stick with those
Old Jan 16, 2005 | 11:01 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Sweet! Thanks Mike. Now I have to make up my mind on which brand tires I should get .
Old Jan 17, 2005 | 05:51 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
you can run 275/30 in the rear no problem
Old Jan 17, 2005 | 08:41 AM
solidsnake's Avatar
solidsnake
I was told that its 255/30 and not 255/35 in the front. Im going with the bfgoodrich kdw's. Whats the difference between 255/30 and 255/35??
Old Jan 17, 2005 | 02:40 PM
xxlbeerZ's Avatar
xxlbeerZ
I have the same size wheels.
I had the tire place mount up a 285/30 and a 275/30, I ended up going with the 275/30. It looks much cleaner, the 285 looked to bubbled out on the 10" wheel. I would probably do 285 on a 10.5" wheel, but not on a 10". As an added bonus, you get many more choices and price range with the 275.
I went 245/35 in the front, but 255/30 would have been fine as well.
It's really just preference, I prefer the squared up look with these size tires, especially with wide lip rims. Bubble tires really destroy the look at an angle if they stick out past the lips.
Some people say the 285 may provide more curb protection, but honestly, with rubber band tires choose what looks better since neither tire is really going to protect your rim if you curb them.
Old Jan 17, 2005 | 02:45 PM
xxlbeerZ's Avatar
xxlbeerZ
pic, as you can see tires are not stretched at all at 245 and 275, they even still have a bit of room. This size tire you can still see both sides of the wheel even at extreme angles...
Old Jan 17, 2005 | 03:02 PM
solidsnake's Avatar
solidsnake
Any pics with the 285/30's on?
Old Jan 17, 2005 | 03:06 PM
solidsnake's Avatar
solidsnake
Got more pics of your car? It looks awesome and I like the drop. You got the Hotchkis springs? Any problems with them and how was install??
Old Jan 17, 2005 | 03:12 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
After looking more into this...I checked this site http://toy4two.home.mindspring.com/tire.html and it seems that 255/30 would be the best fit since it'll keeps the error within .5 MPH. The main thing I was told is to make sure the tire diameter is as close as possible to your OEM setup. I'm in the same boat as you are so I'll be doing some more research as well. Thanks for your input & pics xxlbeerZ. Like solidsnake, I wanna see how the 255 & 285 setup looks like. If it's significantly bubbles out like you say, I might go the same route.
Thanks,
James
Old Jan 17, 2005 | 06:05 PM
solidsnake's Avatar
solidsnake
I order my tires tomorrow. For sure im going with 255/30 on the front but now im stuck with the decision on the rears. Between 275/30 or 285/30. Input would be highly appreciated.
Old Jan 18, 2005 | 10:22 AM
saint01's Avatar
saint01
My axis seven mods will arrive today, and I am getting the BF Goodrich KDW2 285 30's on the back. Search the site and you will find a picture or two of a couple of guys that have these exact rims with the 285's on the back. they actually don't look much different than the 275's above. I think they could actually come out further.
I ordered my wheels from Tom at WheelStudio. He recommended going with either the 285 or the 295, although you can go as high as 305's. Tom seemed to know what he was talking about, so I went with the 285 in the rear.
Old Jan 18, 2005 | 02:03 PM
omarv6's Avatar
omarv6
255/35/20 F & 285/30/20 R this i what i got from lowenhart instaled on the rim.
Old Jan 18, 2005 | 02:32 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
aha! I knew I saw a few people on this site that was running the 255/35/20's in the front. Hows the ride? Does this setup effect your TCS? Can you please post closer comparison pics of the front and rear tires? Thanks!
Old Jan 27, 2005 | 12:06 PM
solidsnake's Avatar
solidsnake
Ok I tried oerdering my tires but they arent in stock. NOO!! Anyways What tire did you guys get? I need to order a set tomorrow. HELP!! I still want to stick with 255/30 front and 285/30 rear.
Old Jan 27, 2005 | 12:18 PM
Chris@DTD's Avatar
Chris@DTD
I just sent you a PM.
Old Jan 27, 2005 | 12:23 PM
solidsnake's Avatar
solidsnake
Ok I found the pirelli pzero in 255/30 and 275/30 for a good price and also I found the Continental in the same size for a little bit more money. Which tire is the best? the pirelli pzero nero or the continental sportcontact 2?
Old Jan 27, 2005 | 12:27 PM
Chris@DTD's Avatar
Chris@DTD
You've got another PM, the website doesn't show them, but I've got em.
Chris
Old Jan 27, 2005 | 09:39 PM
solidsnake's Avatar
solidsnake
Thanks Chris. Your a lifesaver. I highly recommend you over tirerack anyday. Thanks again. Ill post pics as soon as I get them on.
