Paint vs. Powdering
Old Jan 31, 2005 | 04:49 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Default Paint vs. Powdering
Which would you rather have done to your wheels and why. Which chips easier. $$$ isn't really a factor. Thanks.
Old Jan 31, 2005 | 05:14 PM
Clifton in AZ's Avatar
Clifton in AZ
Powder coating is thicker and more durable. It woun't be as shinny as a nice sprayed on paint but it would be more resistant to scratches and chips.
Old Jan 31, 2005 | 06:26 PM
2003z's Avatar
2003z
Powdercoat is a polyester powder, that when melted and cured is not necessarily thicker than paint, but is much more resistant to scratches and chips. It can also be just as glossy as paint. Many powders have a 95% gloss rating, and there are even 95% gloss clear coats you can put over a less glossy color. Personally, I use a flat or satin to bring the gloss down on some things I have coated.
Old Feb 1, 2005 | 05:38 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
powder coading is much strogner then paint. it can look just as nice. you can put any type of metallic flake in powdercoating but then you require clear coat.
i believe powdercoating actually static chargest the powder to the object and then it bakes the powder on to melt
Old Feb 1, 2005 | 06:25 AM
2003z's Avatar
2003z
yes it does. the part is grounded and the coating gun is positively charged with a small amperage and 10000 volts. The powder is then attracted to the part.
Old Feb 1, 2005 | 07:31 AM
mdacko's Avatar
mdacko
how long does that G2 caliper paint usually last? im thinking about doing mine in gloss black
Old Feb 1, 2005 | 10:02 AM
Clifton in AZ
I've used VHT engine paint on cailpers. It's good to 500*F. Under $5 a can.
Old Feb 1, 2005 | 10:39 AM
mgl's Avatar
mgl
for wheels, its better to powdercoat
for calipers, paint is ok, but powdercoating is better.
Old Feb 1, 2005 | 12:18 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
It's for wheels. I'm gonna go with powdercoating. Thanks for everyontes imput
Old Feb 2, 2005 | 03:48 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
One more question. Will I need to strip the wheels before I take them to the powdercoating place? I have the centers seperated from the outer lips since I have 3 piece wheels. I'm guessing you can't powdercoted over paint or, maybe you can?
Old Feb 3, 2005 | 07:04 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
You won't need to strip them, but i think the shop will. I may be mistaken, but i think for powedercoating, you need to sand off any coating, so that the powder will stick to the actual metal. Also any coating that is on there, will act as a blocker for the charged particles being attracted to each other.
Old Feb 3, 2005 | 08:27 AM
GATORZ's Avatar
GATORZ
Default Powdercoating
ZU L8R,
I bought a set of Track Rays and they are being powdercoated today. Hope to check them out tomorrow and take some pics. They are metallic and WILL need a clear coat yet. I had to get them glass bead blasted which is sandblasting with glass for the most part. It is not quite as harsh as sand. I then had the lips polished to high gloss. Had to get some special tape and tape off the lip before powdercoat and will have to tape again before the clearcoat unless I clear the lips. I have some pics at home I'll post when the project is done. Powdercoating cost me $25 per wheel per coat. Total $200 for metallic with clearcoat.
Hope that helps,
Dan
Cashwin
Oct 1, 2015 06:36 AM
