Volk SF Winning Wheel help
I'm running 9.5 / 10.5 +22 all around with the same tires you are talking about. Front fits fine, still have more room so you should be OK. I rolled the rears but only slightly and I am set at-1.8 with no rubbing at all. So while I can't guarantee you'll be OK, it sounds like you should be albe to fit it if you are cutting the fenders.
The fronts are a little more stretched than the rears though as you mention, but combos fall within spec. I don't really notice the stretching anymore as I'm pretty used to it, but it's definitely not like doing 245 / 275 on 8.5 / 9.5.
Sorry, but I'm not sure about the lips.
i think i might do 19x8.5 front with +23 offset. will this work on a lowered get 245 35 19 because 19x9.5 with 22 offset and a 19x8.5 with 23 offset will the lip be close to the same on teh 2?
Originally posted by g35tt
i have the sf-winning 19x9.5 front with +19 and 255/35/19 and for the rear 19x10.5 with +17 offset and 285/35/19 all i did was rolled the rear so it wont scrape.. perfect fit allaround....
here a re some pics!!!!!!!!
clik......http://www.importspeedmagazine.com/f...5/juliog35.htm
