350Z Nismo wheels on a Maxima?
I know this is slightly off-topic but does anyone know if the 18x8.5" front 350Z Nismo wheels will fit on all four corners of the new model Maxima. My wife is looking at the Maxima and she loves the Nismo wheels on my Z. It appears as if they should fit. The stock Maxima wheels are 18x7.5" with the same bolt pattern, but does anyone know for sure?
Originally posted by Z1 Performance
I'd thnk the offset would be a bit aggressive as the Max is a FWD car
Performance Nissan
Performance Nissan
offset it too low for the max... you would need soemthing more along the lines of low 40's offset... ie +43mm...
We can get you TE37's in the offsets you will need...
Basicly the wheels / tire will be sticking out almost an inch past the fender = RUB@!
Jason I asked you on page 1:
https://my350z.com/forum/showthread....0&pagenumber=1
Anyway sorry for the hijack again. Im out
Performance Nissan
Performance Nissan
Originally posted by lovetoclown
what about me?
what about me?
I thoguth I made it pretty clear that you are not going to get close to the performance of the tilton set up with either of the clutches / flywheel set ups you mentioned... The tilton street set up behaves just like the stock... all you would need to change out is the clutch, that is if the flywheel isnt distroyed but i doubt it is...
Performance Nissan
Performance Nissan
We no longer install non-carb approved parts for CA residence...
If you want the stillen... what type of hood would you like with it? STB? etc... how long can you leave the car...
Performance Nissan
Performance Nissan
Jason, Can you install non carb parts for out of staters? Like cams and stuff.
I found a set on eBay that would apparently fit the maxi.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Performance Nissan
Performance Nissan
Those are NOT LMGT4's... he has a picture of LMGT4's...
the ALTIMA NISMO Wheels that fit are these...
I can do them for $350 per wheel for forum members...
they are instock as well...
The NISMO wheels that person is selling are NOT lmgt4's...
