Spacer costs
Old Feb 22, 2005 | 06:47 AM
aleicgrant's Avatar
aleicgrant
Default Spacer costs
Hey there, I have a set of Axis Mod 7's to be put on and I need spacers for the front tires. How much should these run roughly. I have been told H & R is the best. comments
Old Feb 22, 2005 | 08:03 AM
King Tut's Avatar
King Tut
Direct from the H&R website ( http://www.hrsprings.com ):
TRAK+ Wheel Spacers
DRS 5mm 15 1065662 $ 68.95 Pair
DRS 15mm 15 3065662 $ 119.95 Pair
DRS 20mm 15 4065662 $ 125.00 Pair
DRM 25mm 5065662 $ 149.95 Pair
Old Feb 22, 2005 | 08:11 AM
aleicgrant's Avatar
aleicgrant
awesome. Now how do I figure out which size i need. I have a 03 G35 coupe with Brembos. I beleive its only the fronts which need the spacers. This is a 20 inch rim 9.0 with a 35 offset.
Old Feb 22, 2005 | 09:52 AM
grifferjr's Avatar
grifferjr
TRAK+ Wheel Spacers
i am in the same situation and want to get going on these. how can you be sure that they will match up with the aftermarket rim. I have already spoken with someone about having some machined and he was asking all kinds of measurements concerning my rim, like center bore cut, etc. are the ones from H&R unique also?????
Old Feb 22, 2005 | 11:48 AM
King Tut's Avatar
King Tut
The ones from H&R are setup to be exactly like the stock 350Z hubs so that any wheel that fits without the spacer will fit with the spacer. They are 350Z specific. They make the center hub the exact same size and the spacers are hub centric. You can read about them on the H&R website.
Old Feb 22, 2005 | 12:32 PM
grifferjr's Avatar
grifferjr
thanks for the info. but then how do i make sure that the rims I have are the same. i have tsw thruxtons and need to find out center bore. the discount tire i got them from was very vague and even stand-offish because they dont do anything with spacers.
Old Feb 22, 2005 | 01:14 PM
King Tut's Avatar
King Tut
They should have come with hub centric rings that make the wheels mate up with the stock 350Z hubs perfectly. If you didn't get those, then I would recommend getting a set instead of using custom wheel spacers with a different hub size.
Old Feb 22, 2005 | 02:43 PM
grifferjr's Avatar
grifferjr
thanks a lot. i really am out of my league when talking about these things. they did come with the rings cause when i had my winters put on they gave me a bag of hardwear, lug nuts and those rings now that i remember them. spacers are cool to use with those rings???
Old Feb 23, 2005 | 04:57 AM
King Tut's Avatar
King Tut
The spacers will go on over the hub and then those rings will be used on the spacers just fine. It is just like you are making the hub wider so the wheels stick out more. The mating surface and hub will be the same size as the OEM hub.
Alexreyes
Sep 30, 2015 11:30 PM
