+19 offset in the rear question
Old Mar 12, 2005 | 10:42 AM
sroks5's Avatar
sroks5
Default +19 offset in the rear question
19" rims with + 19 offset, do I need to roll my fenders?
Old Mar 12, 2005 | 11:26 AM
Zivman's Avatar
Zivman
What width wheel?
Old Mar 12, 2005 | 08:51 PM
Strife350z's Avatar
Strife350z
at or below 10.5 you should be fine without needing to roll your fenders
are you lowered? if you are then you *might*... depending on tire width and size of the drop
Old Mar 13, 2005 | 05:59 AM
Losing Grip II's Avatar
Losing Grip II
i have 10.5 rear with 24mm offset and at certain speeds and bumps, my rear will rub slightly. im lowered about inch but have coilovers which have a high spring rate than springs. i think even with a 9.5 rim you will rub. anything higher than 9.5 and YOU WILL NEED TO ROLL YOUR FENDERS. even at that point, i seriously would consider not going with 19mm offset. when i compare that to mine, 5mm more than mine, i think you might be in the realm that rolliing wont be enough to avoid fender damage.
john
Old Mar 13, 2005 | 08:56 AM
sroks5's Avatar
sroks5
its a 10.5 rim and not lowered.
Old Mar 13, 2005 | 12:48 PM
Losing Grip II
pretty sure it will rub and rub badly. even if it doesnt rub, because of stock height, the wheels will stick out about an inch from the fender.
i think it will rub tho. even with stop height, the stock springs aren't high enough of a spring rate and therefore will compress enough to rub.
john
p.s. do u own these rims yet?
416blueZ
Jun 11, 2024 10:56 AM
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
