The Doctor Needs Some Help STAT!
I am in the process of putting my new wheels on. Did the fronts with no problem but I CANNOT GET THE REAR WHEELS OFF! Car is up on jackstands and all 5 lugs are removed but the rear wheel will not budge! Is there something that needs to be loosened or removed from the INSIDE of the wheel?
Help STAT!
Help STAT!
on
ditto..
or you can kick around the tire gently until you see the rim getting away from the hub. You will get it off that way eventually, just take your time. I wouldn't hit the rim at all, even with a rubber hammer. Work on the tire's outmost edge gently.
on
Shouldn't have to remove anything other than lugs. Any chance there just being a little rust (weld) holding them on try spraying on WD40 on lug /wheel areas then rubber hammer or BFH if that doesnt work
Had a Lincoln come in once with Thunderbird wheels and tires, FROM THE FACTORY. We took the lug nuts off, only to discover that the wheels were PRESSED onto the axle hub.
With all the lugs off, the owner of this car was determined to get the wheels off......by doing donuts in our parking lot.
Around and around he went. Faster and faster until smoke filled not only our parking lot, but the grocery store's next door too.
Eventually the cops came and were as amused as we were.
Never did get those wheels off.
I know this was no help....sorry.
350Z_Al
10-29-2020 07:44 PM
Workshop12
03-23-2020 01:45 PM
