Question on volk SF challenges...
Old Mar 20, 2005 | 02:33 PM
bobS's Avatar
bobS
Default Question on volk SF challenges...
I'm looking to buy new wheels and have my mind made up on volk SF challenges. I know its a popular wheel but i don't care i really like it. Sooo would someone be kind enough to give me some advice on what size/offset will fit?
I'm looking to buy 19's, i know that. I will be lowering the car on coilovers so i don't want to have a problem with rubbing. Finally, i will be installing a big brake kit only on the front wheels. I'm thinking 19x9 on the front should clear the BBK and 19x10 on the rears will give me a nice lip. What offsets should i go with? Also anyone have any suggestions on where to purchase them? Experiences good or bad? Thankksss
Old Mar 20, 2005 | 03:20 PM
PumpedVA's Avatar
PumpedVA
I might be wrong but I think they only come in one offset for that size wheel.
Old Mar 21, 2005 | 02:00 PM
bobS's Avatar
bobS
Yea i think your right, sorry i don't think i worded my question very well. What i'm asking is what size wheel should i buy? I def want 19's, i def. want a big rear lip, and i also don't want the tires to rub when i drop it on coilovers. I'm just a little confused on what width i should get/offset and tire size. Oh also i need the front wheel to clear stoptechs...thanks
Old Mar 21, 2005 | 02:16 PM
atftrading's Avatar
atftrading
hey i have sf channege on my car with this set up fronts are 28 offset 19 9.5 with 245 35 19 toyos and the rear i have 10.5 with 275 35 19 with a offset of 23 no rubbing at all very clean but if you want a bip lip in the rea i should shuggest you gett the volk gt7 the 10.5 model has like a 4.5 inch lip on the gt7 very nice i hope this helps alittle
Old Mar 21, 2005 | 03:38 PM
bobS's Avatar
bobS
Thanks that does help. Do u have any pics?
Old Mar 21, 2005 | 04:15 PM
shimz350z's Avatar
shimz350z
even if it a lot of people have it...I DON'T THINK YOU'LL REGRET IT AT ALL.
It compliments the z very well. Still smiling everytime I go outside and look at the car.
Old Mar 22, 2005 | 08:06 AM
bwzabodyn's Avatar
bwzabodyn
the sizes I would go with are:
19x9.5 +28 front
19x10.5 +23 rear
255/35 front 275/35 rear (285's might rub) - Good luck!
Old Mar 22, 2005 | 09:46 AM
atftrading's Avatar
atftrading
hye here is the link when i got the new sf https://my350z.com/forum/wheels-and-tires/111787-out-with-the-oldrims-and-in-with-the-new-rims.html
Old Mar 22, 2005 | 02:33 PM
xephiron's Avatar
xephiron
Why get a 10.5 inch rim for a 9 inch tire? (275) I guess people like to see tires angle in off the rim in a V-shape, so people ask "why don't you get tires big enough to fit your rim? Not me, 8.5 front with 255, 9.5 rear with 285 on 19 inch rims, 30 or 35 profile not 100% sure on that combo yet, but I don't have rims yet either so no hurry.
Old Mar 22, 2005 | 04:28 PM
FairLady350zZ's Avatar
FairLady350zZ
That is correct, if you want to run 9.5 in the front and 10.5 in the rear then go with a +28 front and +23 in the rear. On the other hand, since you want a big brake kit in the future, run a +15 in the front with a +23 in the rear on 9.5 and 10.5. Here are some shots of my SF Challenges I just got in from Bryan from 350zonline....
Old Mar 22, 2005 | 04:43 PM
35oZephyR's Avatar
35oZephyR
19x9.5 +28 front
19x10.5 +23 rear
Same setup I have.
But I went with a 245/35 and 275/35...
and rolled my fenders.
Dropped on Eibachs, It doesn't look like it would rub at all but I got them rolled to replace the tires with 285's or 295's in the near future.
And for the "v-shaped/ stretched beyond falling of the wheel" comment: It's not that bad.
From my observations...
The lip on a typical 9.5 rear is not as big as a 10.5 with the above offset. Usually, it depends on offsets for the rear-lip but in the case of your typical setup for SF-Challenges. A 10.5 rear in a 23 offset will appear to be deeper than a 9.5 rear in whatever average offsets normally posted on these boards.
Old Mar 22, 2005 | 08:06 PM
PumpedVA's Avatar
PumpedVA
hold on are you guys saying a +23 font will not fit a BBK up front?
Old Mar 23, 2005 | 01:57 PM
bobS's Avatar
bobS
Wow atftrading your car looks sick thanks for the pic, also fairladyzz i really like the gold on ppw, good choice. Ok so a +23 front would not fit a bbk? Any negatives about getting +15 over +23?
Old Mar 23, 2005 | 03:02 PM
atftrading's Avatar
atftrading
hey yea when i bought my sf they gave me a choice of +23 or +28 they said if iam planing too put bbk later the 23 wont fit it but the 28 offset will and for getting over +23 such as up too +22 i think it looks perfect but i wont go over that unless you are going like wide body or something its going too stick out too much if it is pass +22
Old Mar 23, 2005 | 03:37 PM
35oZephyR's Avatar
35oZephyR
I don't know guys...
I have a 28 offset up front and the wheel sits pretty damn flush to the fender while looking like you could fit the world behind those spokes!
Anyone have any confirmation on the 9.5's BBK front compatability in these offsets?
btw: I don't know if this explains anything but I went out to measure my front wheel. Looks like the most shallow part of the spoke sits almost 2' inches away from the stock caliper. Does a typical BBk portrude out THAT much farther???
Old Mar 23, 2005 | 07:23 PM
hardguy's Avatar
hardguy
How bout if you plan on putting BBK on all 4 corners? What should the offset be on the 9.5" & 10.5" combo? Thanks in advance.
Old May 10, 2005 | 07:18 AM
NISMOFO's Avatar
NISMOFO
So will the +28 offset on a 19x9.5 work in the front with Brembos?
Old May 10, 2005 | 09:34 AM
FRLDYZPIMPN's Avatar
FRLDYZPIMPN
Im running 19 x 9.5 + 23 and 19 x 10.5 + 21 w/ 245-35-19 275-35-19 on eibach springs. Does not rub at all, but it will w/ a 285-35-19 only if u drop.
Attached Thumbnails Question on volk SF challenges...-the-rear.jpg   Question on volk SF challenges...-the-side.jpg   Question on volk SF challenges...-wall.jpg
Old May 10, 2005 | 08:08 PM
35oZephyR's Avatar
35oZephyR
It HAS to work!
I can almost bet my wheels on it. There is SOOOO much room back there.
I'd imagine going lower on the offset will give it less room.
Old Jul 26, 2005 | 12:32 AM
sokudo9l6's Avatar
sokudo9l6
Ok..let me get this straight before i order rims. If i want to get a BBK later, i should get 19x9.5 +28 in the front? And the 19x10.5 +23 will not rub unless i use 285/35/19 tires? What if i use 275/35/19 tires in the rear and lower the car 1in or 1.5in? Will i need to roll my fenders to avoid rubbing? I really want to avoid having to roll my fenders later.
I also have a question about le37s. If i get 19x9.5 in the front and 19x10.5 in the rear with +22 offset all around...will i have any rubbing issues? I plan to lower my car about 1inch to 1.5in.
issyz
Jul 2, 2017 03:04 PM
