Offset required for a 9.5"/10.5" w/ 255/285?
Old Apr 1, 2005 | 05:25 AM
StefanZ's Avatar
StefanZ
Default Offset required for a 9.5"/10.5" w/ 255/285?
What offset is required for a 9.5"/10.5" with 255/35-19" and 285/35-19" setup? My favorite wheel is the RH J8, but my favorite color, SBC, isn't available in that size - so I'm considering either the SBC 9"/10", still equipped with 255/285 (will the usual +26/+19 setup accomodate the 255/285 tires, or do I have to stick with 245/275??) or, go with RH J8s in silver so I can have 9.5"/10.5" - but the question would still be at what offset can I get those to not have to roll the fender, and still fit 255/285s?
TIA~!
Old Apr 1, 2005 | 11:37 AM
StefanZ's Avatar
StefanZ
Can I get an a----bump----men?~!?
Old Apr 1, 2005 | 12:02 PM
sentry65's Avatar
sentry65
the burninator
around 28 front and 30 rear would work fine
Old Apr 1, 2005 | 04:21 PM
StefanZ's Avatar
StefanZ
That seems pretty conservative to me.....because a +26 on a 10.5" works fine when equipped with a 275 series tire..and I've also been advised that a 285 would fit with no mods necessary. Are you just being careful?
Old Apr 1, 2005 | 06:52 PM
350G's Avatar
350G
I have +22 all the way around with 8.5 fronts & 10.5 rears . . . . 285s on the rear as well. With stock suspension, no issues whatsoever.
Old Apr 1, 2005 | 07:54 PM
StefanZ's Avatar
StefanZ
350G: how many more mm's do you believe you could have gone outward and still remained safe from rubbing? How close do you believe you are? Do you have pics?
Old Apr 1, 2005 | 09:32 PM
Speed Dreams's Avatar
Speed Dreams
...Wooo, that's a big off set on 10.5 with 285 tires.....
I have Volks, 9.5 with 245/35-19 +30, and 10.5 with 275/35-19 +24. Front lip is 2 3/4", rear is almost 4".
In my opinion I could have gone a 255 on the front but with the rear off set a 285 would require rolling at my ride height, they are just to the edge.
Looks with the deep dish...10+....JMHO
Old Apr 1, 2005 | 09:59 PM
BoostTed's Avatar
BoostTed
just for reference I had SF-challenges 19x9.5 in the rear with a 23 offset i believe, 285.35.19 tires and I rubbed going over bumps in the road. I'm on eiback springs as well.
Old Apr 1, 2005 | 10:00 PM
StefanZ's Avatar
StefanZ
SpeedDreams: you've lowered your car how much? You're saying that your 275's are riding so close to the inner edge of the fender that another 2.5mms would rub? Is that what I'm hearin? How far do you believe you could lower your car and have the 285's work at your +24 offset?
Old Apr 1, 2005 | 10:04 PM
sbcbaseball's Avatar
sbcbaseball
i have the 19 inch racing hart cpf-tuner in sbc and they are 9 inch in front and 10.5 in back. i dont know the offset but they only come in one size only.i purchased michellin ps2 265/30/19 for front and 295/30/19 in rear. i shaved fender and no rubbing. life is good.
Old Apr 2, 2005 | 05:30 AM
StefanZ's Avatar
StefanZ
Speed Dreams:
Rickdogg (look him up) has Volk 19x10.5" rears +24 dropped fully with Teins, and he says no rubbing...
Man I'm getting conflicting opinions!
Old Apr 2, 2005 | 05:31 AM
StefanZ's Avatar
StefanZ
How do you feel about breaking the cherry on the factory rust protection on the area of the car most prone to corrosion? That would freak me out..course I'm in saltville....not that I drive my Z then anyway....
Old Apr 2, 2005 | 07:54 AM
sbcbaseball
since i live in cali, we break cherrys quite often hahahaa.....rust is the least of my worries.
Old Apr 2, 2005 | 09:11 AM
350G's Avatar
350G
Here's the pic of the +22s all the way around on stock suspension . . .
Realistically, I think 285s might have a rubbing issue if you drop the car over an inch . . . the Espelir 10mm drop would have no serious problems. Using the 285s I have now, it makes the tire stretch a bit to fit the rim. I can't imagine a 275 on it
Old Apr 2, 2005 | 12:24 PM
Speed Dreams
Originally Posted by StefanZ
Speed Dreams:
Keep in mind that I have a roadster, they ride lower due to some added weight. My Tein basics were initially dropped all the way when we mounted the Volks. They didn't rub but were at the edge with a 1/4" of space. I believe if I took a big bump they would have rubbed. I raised the rear 8 threads last night an have about 3/4" clearence now but still quite a bit of - camber. I might take it up a bit more, at this point I am about 1 3/4" lower then stock.
My only concern for you was the tires sticking out of the fender well, this may depend on which tire manufacturer you use. I have Toyo Proxes T1S.
I like the lower look on my car so the 275 is max for me. I agree that if you don't lower more then 1" you should be ok.......Good luck, and I don't blame you on a larger foot print, I would put 295's on the rear if I knew they would fit.
Tripp
Old Apr 3, 2005 | 02:16 PM
StefanZ's Avatar
StefanZ
Very nice car 350G: great taste!
I'll have +26 on my rears, in a 10.5", or a +19 rear with a 10". Either way, it will be 4-5mm in more than your setup, so that makes me sure that the 285 will fit safely, even if I lower it. Zounds great, and TY for the help!
Old Apr 3, 2005 | 05:45 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
humm...what kind of cherry are we talking about here eh? hehehehe
Phenom
Oct 31, 2014 04:52 AM
scotts300
Wheels Tires
Apr 4, 2012 10:13 PM
scotts300
Apr 4, 2012 10:12 PM
jrforrester
Nov 14, 2006 02:11 AM
ZinMiami
Nov 21, 2004 07:32 PM
