What is the widest wheel you can put on the Z
Old Apr 1, 2005 | 11:40 AM
Supertouring's Avatar
Supertouring
Default What is the widest wheel you can put on the Z
I was looking at wheels again. I have 19 inch Axis supermesh whels on it now and I was just wondering what was the widest wheel I can fit on the Z, but on an 18 inch size?
Old Apr 1, 2005 | 11:43 AM
TakeiteZ's Avatar
TakeiteZ
it all depends on the offset.... and how much you want it to stick out of the fender, and if you want to roll your fenders...
I dont think you'd be able to fit more than an 11inch rear with less than a +28 because it'll rub agaisnt the suspension... and you'd definitely have to roll your fenders with any offset less than that.
oh and tires would make a difference too. Im not that educated on wheels so someone else probably has a better answer for you!!
good luck!
Old Apr 1, 2005 | 11:45 AM
StefanZ's Avatar
StefanZ
My guess is 275/295, without rubbing, but it depends upon the rim and tire, as well as whether you have a BBK - and I'm still in the process of finding out definitively. I want to go with a 255/285 setup on 9.5"/10.5", but am still trying to find out how. The answers are all over the board, and it's confusing. What size rims/tires/offsets are your Axis Supermesh?
Old Apr 1, 2005 | 12:31 PM
wookie's Avatar
wookie
stefanz , in avatar its your car ?
can u post more pics
interesting
Old Apr 1, 2005 | 12:42 PM
TakeiteZ's Avatar
TakeiteZ
his avatar looks like a photoshop... but if that's really a car then :O
Old Apr 1, 2005 | 01:54 PM
Supertouring
I have 9.5 on the rear and I think they are 8.5 on the front I was just wondering what my limit was for the rear. I think the front are fine, but when I look at the rear tires it looks like it could go a little wider. I don't know if it screw up the handling of the or anything, but if I could go wider I would like to.
Old Apr 1, 2005 | 02:32 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
9.5 with +21 offset with 245 tires [Front]
10.5 with +24 offset with 275 or 285 tires [Rear]
If you want to have bigger than 10.5, you will have to modified or have widebody to cover it nicely.
Old Apr 1, 2005 | 03:20 PM
G3po's Avatar
G3po
Default big wheels
I run 265/35-18 (9inch wheels) front and 295/35-18 (10.5inch wheels) back.
Note this provides ~.7" stagger and doesn't **** of VDC. They fit prefectly and don't bug out of the fenders at all.
To run 265s in front you need ~31mm offset. 275s would fit ;however the stagger will be too small to keep VDC happy with 295s in the rear.
To run 295s in the back you need ~43mm.
Less offset front and back will simply make your wheels bug out more and interfere with the fender lipt if lowered.
Old Apr 1, 2005 | 07:50 PM
StefanZ's Avatar
StefanZ
G3po: are you able to post pics of your car, or give us a link? I'm curious what your set up looks like. Perfect in one person's eye isn't always in another ya know....
Old Apr 2, 2005 | 05:50 AM
StefanZ's Avatar
StefanZ
chitty chitty bump bump
Old Apr 2, 2005 | 10:39 AM
MY350Z.COM's Avatar
Brembo car had 18X11's with a conservative offset.
With the right offset you can probably fit even more underneath.
Old Apr 2, 2005 | 03:25 PM
speedform's Avatar
speedform
I've heard the Z could run a 315 series tire in the rear, with, as Mike above stated, a conservative offset.
Old Apr 3, 2005 | 10:45 AM
03Z33's Avatar
03Z33
check out page 2 on my cardomain:
http://www.cardomain.com/memberpage/690990
I fit these as a joke just to see if it would work and they do!
18x12.0 et22 rear w/255/35/18 tires , these will not rub on the stock fender!
18x10.0 et22 front w/235/35/18 tires, these would have worked if I didn't have the brembos, I had to use an 18mm spacer to clear the brakes and they still fit just barely, but didn't look safe to drive.
I've also seen 315's in the rear of a Z on 18x11.5's but that car had the fender rolled (and maybe pulled just a bit)
Old Apr 3, 2005 | 12:43 PM
Machupo's Avatar
Machupo
exactly what i was looking for -- those are the sizes / offsets i'm getting, woohoo!
Old Apr 3, 2005 | 12:54 PM
sbcbaseball's Avatar
sbcbaseball
That is correct its all about offset,i have the sbc cpftuner 19's...front 9inch and rear is 10.5 with 265/295-30-19 set up and no rubbing.most tire places would not sell me tires bcuz they said it would rub and they dont.btw my car is lowered abt 1.5....just a heads up i did notice my car seems a bit slower. The handling on the other hand is much better, car feels so planted.its tt time.
Old Apr 4, 2005 | 07:43 AM
G3po's Avatar
G3po
Default fat tires.
Sorry , I don't have pics with me, but it looks pretty OEM. I sway towards "un-bling" and more towards function. My wheels are SSR Comp-Hs.
It's hard to find a set of wheels with the width , offset at that reasnable cost point. Oh BTW , my car is a G35C, but the wheel clearances are comparable.
Old Apr 4, 2005 | 07:46 AM
G3po's Avatar
G3po
Default wide tires
Yeh , you can go larger , but you'ld **** of the VDC. There is an easy extra inch or more of growth rookm in both my font and back. IF 305/315s came in the right diameter , I'd be all over-em. But it's a reasnable compromise.
Old Apr 4, 2005 | 07:50 AM
G3po's Avatar
G3po
Default wide tires
Oh ,yeh I run PS2s , so far great tires, just pricey.
Kinda hate to burn em off.
Old Apr 4, 2005 | 08:23 AM
JimRHIT's Avatar
JimRHIT
Al,
what brand of tires did you go with. I have the same size and offsets on my racing harts as you ... so I would like to go with that tire setup as well.
Let me know man. thanks
TT time ... yummy
jim
Old Apr 4, 2005 | 08:26 AM
sbcbaseball
Jim,
I went michellin ps2.. they are great. I will be at chads house this sunday cruise by and check them out.
Al
