I have 19" Axis Hiro's and have question...
Old Jun 27, 2005 | 03:23 PM
lascala26's Avatar
lascala26
Has anybody with the 19" Axis Hiros been able to install the TPS? I need to get my Hiros put on and I need to know if I am going to be able to do this. Thanks!
Old Aug 12, 2005 | 03:51 PM
james axis's Avatar
james axis
Try 265/30-19 And 295/30-19 Pirelli Pzero, Best Fit
James Chen
Axis Wheels
Old Aug 13, 2005 | 04:17 PM
csmith82177's Avatar
csmith82177
I have Axis Hiro 19X8.5 in front with 245/35/19, 19X9.5 in rear with 275/30/19 and no gap, fits perfectly. Your wheels are an inch wider and you have an inch of room between wheel rim and tire. I would return either the wheels or the tires to Tirerack.
Old Sep 15, 2005 | 11:21 AM
cocos350z's Avatar
cocos350z
Thumbs up
Originally Posted by King Tut
What did you expect when you bought 9.5" and 10.5" wide wheels? If I was you I would move the 9.5" wheel to the back and switch to a 8.5" in the front and then run the standard 245/275 tire setup and don't worry about rubbing and the tires will sit more flush.
Excellent advice. Just what I've been seeking for over a month. Will do & thank you! ...but, the wheels won't be Axis.
Old Sep 15, 2005 | 12:43 PM
jjellyneck's Avatar
jjellyneck
Why not Axis? Does this mean that you're selling them?
Old Sep 15, 2005 | 12:48 PM
lascala26's Avatar
lascala26
Just a FYI.....TPS works perfectly with Hiros. No modification necessary.
Paul.
Oct 16, 2015 07:34 PM
35reilly
Sep 28, 2015 07:42 AM
HXS
Jul 12, 2003 04:53 PM
hk350
Mar 12, 2003 01:14 AM
Heat
Feb 12, 2003 04:41 PM
