18" lmgt4 and wheel spacer?
ive got the regular 18" Nismo LMGT4s 8.5 f and 9.5 r
anyone know if it's possible (rubbing) to use a 5mm spacer on either front, rear, or both?
TIA
Harv
TIA
Harv
Performance Nissan
Performance Nissan
you could do a spacer on the lmgt4's... 5mm at most f&r i would say...
but...
My rear wheels would rub all the time on my stock fender when I drove my car hard... with no spacers
but...
I have the Nismo LMGT4's also and my question is, is it possible to add more than 5mm spacers front and rear? I'm thinking 15mm to 20mm front and 25mm rear without rubbing?
Thanks
Thanks
Performance Nissan
Performance Nissan
no...
I would rub with 275/40/18 in the rear on my LMGT4's with the stock fenders...
YOu could do 5mm spacer front and rear ...
I wouldnt go more then 5mm up front... maybe 8mm at the max but those wont be hub centric so not exactly safe...
and the rear you could roll your fender and then run a 15mm spacer...
back from the dead. so its not possible to get a 20 mm spacer on my rear.im running a 18 inch Lmgt4 and im wondering whats the best spacers out there,trying to get a more aggressive look.thanks for the help.
Whats size tires are you running on your rears? Just roll your fenders, run a more negative camber, and call it a day.
