my car feels like its all over the road now
Old Apr 25, 2005 | 06:30 PM
EdgeOfSanity's Avatar
EdgeOfSanity
Default my car feels like its all over the road now
I recently had a set of nitto 555 rear tires installed on my z at discount tire. When i first went in for the rear tires i had picked up a bolt in my right rear potenza. I had them replace it with one 555 and had the other one installed the next day because they had to order it. I didnt notice any problems when driving with just the one new tire. But now that i have both on the rear of the car feels like it floating all of over the road at highway speeds. I thought it might be a tire balancing issue at first, but it doesnt shake or anything. The rear just feels like its slightly pulling left then right then left and so on. Could this be an alignment issue or a problem with the tire?
Old Apr 25, 2005 | 06:33 PM
mario60185's Avatar
mario60185
Chicago Realtor
ive never expeirienced that man. but it sounds like something is wrong with your suspension geometry. have you curbed anytyhing lately?
Old Apr 25, 2005 | 06:48 PM
EdgeOfSanity
i barely rubbed a curb with my right rear about 3 months ago. I just barely nicked it, didnt cause any damage to my rim whatsoever. The front of the car needs an alignment, i know that for sure. It pulls right if i let go of the steering wheel, but the problem im experiencing is coming from the rear of the car with both hands on the steering wheel. I also noticed right after getting the tires installed there is a squeaking noise now coming from the rear of the car at low speeds whenever i give it gas or shift.
Old Apr 26, 2005 | 05:13 AM
mario60185's Avatar
mario60185
Chicago Realtor
id get an alignment and check up on it. Sounds like that curbage is worse than you thought.
Old Apr 26, 2005 | 05:34 AM
NismoGCoupe's Avatar
NismoGCoupe
its the tires, nitto is not a good tire they are pretty hard tires what you're experiencing is the lack of traction these tires have, they dont grip the road like the bridgestone's you had
Old Apr 26, 2005 | 05:53 AM
Low J.'s Avatar
Low J.
if your old tires didn't do this then it's definitely not your alignment. You've got a radial tire pull and need to have it replaced. About 1 in 5 high performance tires I've purchased in my life has had a radial tire pull and I've had to turn right back around and have them replace it before I got half way home. I just got a set of tires for my wife's Mazdaspeed and it pulled like hell after the new rubber was on....took it back 3 times for a new tire each time before they got a tire on there that didn't pull....now it's fine. I went through 4 tires on my SRT-4 before I got one without a pull. It's VERY common so just go back and have them keep putting new tires in the rear until the pull is gone.
Old Apr 26, 2005 | 06:10 AM
NismoGCoupe
is the sliding to the point where vdc kicks in? how many miles did you put on them?
Old Apr 26, 2005 | 01:58 PM
EdgeOfSanity
that sounds like my problem, i didnt have the pull at all untill the left rear tire was put on.
Old Apr 26, 2005 | 01:59 PM
EdgeOfSanity
its not that bad, its a very faint feeling at about 80+mph. I doubt anyone else would notice it except me if they drove the car.
Old May 3, 2005 | 08:07 PM
kvjacobz's Avatar
kvjacobz
Default My car does the same thing.
My car (03) has the same problem after I got the new OEM tires on the front and realignment from Nissan and new toyo t-1 proxes in the rear (same size as OEM). The car feels like a sailboat now. It pulls right and then left and then right, etc.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
416blueZ
Sep 25, 2015 10:00 AM
etong
Sep 10, 2015 06:14 PM
