Will a 19" 10.5 rear +22 offset rub with 285/35 rubber?
Old May 3, 2005 | 08:07 AM
Tantrum Z33's Avatar
Tantrum Z33
Default Will a 19" 10.5 rear +22 offset rub with 285/35 rubber?
I'm getting new wheels and wanted to know if 285/35 will rub on a 10.5" with +22 offset. BTW, I'm still on stock ride height.
Old May 3, 2005 | 09:22 AM
JimRHIT's Avatar
JimRHIT
No, it wont. I have that offset on a 10.5 and here is a pic with a 275/35
This pic is at stock ride height, there is no way that a 5mm wider tire (and 3.5mm taller) would be rubbing on that.
If you lower it, then yes, it will rub
Old May 3, 2005 | 09:25 AM
Tantrum Z33
Thanks Jim. So are you say even if I wanted to lower my car about .6 front and rear, it would rub?
Old May 3, 2005 | 09:29 AM
JimRHIT's Avatar
JimRHIT
I am now lowered around .75-1.0 inches ... it varies with the temp I think ... my car is tempermental
I don not rub with a 275/35, but I know a 295/30 will rub ... so I would venture to say yes you will rub in extreme cornering ... and pulling in driveways and such .. but I can't be sure, since I never ran that size.
Old May 3, 2005 | 11:42 AM
Tantrum Z33
Can I put 295/30 on the rear rim with +22 offset if I plan to stay at stock height?If no, how about +35 offset in the rear?
If I can, what will be the ideal front...265/35?
I just want to figure out what tires will give me the most contact patch without having to roll my fenders. Thanks
Old May 3, 2005 | 01:41 PM
atftrading's Avatar
atftrading
i had the same setup 10.5 and lowered on tein stechs no rubing problems here
Old May 3, 2005 | 06:07 PM
Tantrum Z33
Thats great! What size tires did you go with on the fronts? 255/35? Did it interfere with the VDC?
Old May 3, 2005 | 06:33 PM
sbcbaseball's Avatar
sbcbaseball
Im running 10.5 in rear in 295-30-19 ps2 no rubbing. i also shaved fender just to be safe. keep in mind my car has a 1.5 inch drop on tein flex.You should be fine on stock height.
Old May 3, 2005 | 06:39 PM
Tantrum Z33
sbcbaseball- what are your offsets for the rear?
What size tires did you go up front? offset and width?
Does it interfere with the VDC? Thanks
Old May 3, 2005 | 07:13 PM
sbcbaseball
Im running racing hart cpf tuners...i believe my offsets are 22+ ??? I dunno exactly..my fronts are 9 inches, rears 10.5.. im running a 265/295-30-19 combo. Its a nice firm ride, as far as vdc goes i have the kp module that turns it off. I never liked vdc. Our cars are too torquey and it consistenly was messing with my driving. The plus about having 295 is that they look great and they protect your rims.The down side is that they are very pricey.
