difference between 9.5 and 10.5
Old May 10, 2005 | 02:32 PM
LiLxDooD's Avatar
LiLxDooD
Default difference between 9.5 and 10.5
Well i have GT7s, 9.5 in the rear, with a 24 offset. I heard that a 10.5 and a 9.5 dont have much difference in the rear lip. Is this true?
Old May 10, 2005 | 02:42 PM
protocav's Avatar
protocav
the difference between a 9.5" rim and a 10.5" rim is 1 inch. hopefully that helps.
Old May 10, 2005 | 02:54 PM
Christopher's Avatar
Christopher
the difference is (4) @ 1/4 ".
Old May 10, 2005 | 03:09 PM
LiLxDooD's Avatar
LiLxDooD
well someone said although the wheel entirely is wider, the lip width is the same?
Old May 10, 2005 | 03:38 PM
Chris@DTD's Avatar
Chris@DTD
This is what I first thought when I opened the thread.
Actually, it should be right around a 1/2 inch.
Old May 10, 2005 | 03:40 PM
2004z's Avatar
2004z
Sleeps in 350Z
Old May 10, 2005 | 09:37 PM
ZeroGen's Avatar
ZeroGen
Depends on the offset. The 10.5 will have more lip with a higher offset.
Old May 11, 2005 | 05:13 PM
drumma022's Avatar
drumma022
1/2" more lip if you are working with the exact same offset.
Old May 11, 2005 | 07:25 PM
joshbrittain's Avatar
joshbrittain
^^^ what he said. half will be on the lip, the other half will be on the inside of the rim, since offset is measured from the center of the wheel.
Old May 11, 2005 | 08:59 PM
LiLxDooD's Avatar
LiLxDooD
So i was just thinking. I have a 8.5 in the front and 9.5 in the rear. Im thinking, "well hey, i guess the 9.5 lip in the rear isnt so bad, its kinda deep." Then i started thinking well some people have 9.5s in the front and 10.5s in the rear, so what im thinking is deep for my rear wheels some people have it that deep in the their fronts? Man.. I really wish I got 9.5s in the front and 10.5s in the back now. Its like when you get a deep dish wheel, its never deep enough, you want it deeper and deeper.
Old May 11, 2005 | 09:25 PM
joshbrittain
wheels are like computers, as soon as you get them, they are outdated. I just ordered 9.5 fronts, 10.5 rears, and Im sure in 1 year guys will be running 11.5 rears. thats life.
Old May 13, 2005 | 12:32 AM
illZ's Avatar
illZ
LOL
I too am trying to decide between 9.5" and 10.5" rears
Old May 13, 2005 | 08:07 AM
TheInVertKING's Avatar
TheInVertKING
I just got hy Axis hiros 19x8.5 and 19x 10.5
the lip is freaking awesome on the 10.5!
to bad i cant put them on my car is in the shop right now gettin full system install done so ill put them on when i get off work 2nite a 9:30
Old May 13, 2005 | 08:16 AM
joshbrittain
post some pics tomorrow, we wanna see
Old May 13, 2005 | 10:00 AM
King Tut's Avatar
King Tut
I recommend the 9.5, but if you HAVE to have the 10.5 just please don't run a lowly 275 tire on it.
Old May 13, 2005 | 10:08 AM
bstansbu's Avatar
bstansbu
I say 9.5 in the rear for most people. Im not an expert when it comes to these things, but I just feel like a 10.5 inch wheel on a NA Z is just sad, as far as performance. If your all about looks the 10.5 looks kick azz. I ordered the 9.5 rear because IMO its a decent compromise on perf and looks. If your running turbos or super charger, I would def reccomend the 10.5 rear with at least a 285 tire. Peace, BEN
Old May 13, 2005 | 10:10 AM
jlimquest's Avatar
jlimquest
I have 9.5 front & 10.5 rears.
Attached Thumbnails difference between 9.5 and 10.5-rscn1145-medium-.jpg   difference between 9.5 and 10.5-rscn1148-medium-.jpg   difference between 9.5 and 10.5-rscn1147-medium-.jpg   difference between 9.5 and 10.5-dscn1103-medium-.jpg   difference between 9.5 and 10.5-rscn1149-medium-.jpg
Old May 13, 2005 | 11:12 AM
bwzabodyn's Avatar
bwzabodyn
I'm also running the 9.5/10.5 setup (no "lowly" 275 for me though ) - imo, it's all in the offset - your 9.5 rear actually has a 1/4" bigger lip than my 10.5" rear, but my 9.5" front has over an 1" bigger lip than your 8.5 front... it's all preference and what your goals are - I wanted to be able to run a variety of tire sizes, so I went with the woder combo with more conservative offsets (+29 f/r)... that way, if the 285 rear isn't enough after I go F/I, I can upgrade to a 295/30, etc without having to worry about fender rolling, rubbing, etc...
I'm running 255/35 and 285/35 BFG KDW2's btw...
Old May 13, 2005 | 11:47 AM
illZ's Avatar
illZ
Awesome.
Is there a "recommended" 19" width for TE37?
HyperRev vol.2 is loaded with 19x10.5 R / 19x8.5 F sizes.
Even a few Mismatched 19" R / 18" F
Thanks
