For those who've lowered their cars, how bad is your front tire wear?
Old May 11, 2005 | 12:22 PM
2004z's Avatar
2004z
Sleeps in 350Z
Default For those who've lowered their cars, how bad is your front tire wear?
I recently lowered my car with coilovers, approximately a 1.5" drop. I've got the back taken care of, but I am curious to see if I really need to fix the front camber.
If you've lowered your car, how bad did the front tires wear?
I plan on leaving in some negative camber for better handling, but I don't want to be so far out of spec that I go through tires like nothing.
If I can get the fronts close enough to spec, I may just go without front A-arms (especially given their cost).
Some may tell me to get an alignment and find out. This is possible, but I don't want to pay for it twice. I'd rather get everything fixed at once.
I apologize if this has been answered before. I did a search, but I could not find an answer regarding front tire wear.
Old May 11, 2005 | 02:38 PM
taurran's Avatar
taurran
All I know is it's not as bad as my rear tire wear (my rear tires are bald on the inner half).
Old May 11, 2005 | 03:13 PM
formulaZ's Avatar
formulaZ
there isnt any adjustment available from the stock arms. you will have to buy new aftermarket arms if you want to adjust it close to spec. or, you can just cross rotate the fronts every few thousand miles. your front camber should be about 1.5-1.7ish since you are lowered about an inch and 1/2,
Old May 11, 2005 | 03:21 PM
mario60185's Avatar
mario60185
Chicago Realtor
just got my car aligned. dropped it about 1.5". the rear was way off. 2.5* of camber! my guy did the job manually, only way to do it. he got the rears to 1.75 and the fronts were at 1.5 and the adjustments were maxed out. so it looks like if you want less camber in front youll need some new peices. rear is ok. and front kinda. i thinkm nissan speccs are like 1.5 front and rear.
oh and with some work i have 0 toe front and rear.
Old May 11, 2005 | 03:28 PM
2004z's Avatar
2004z
Sleeps in 350Z
I realize I can't adjust the camber stock. But what I want to know is if front A-arms are really even needed. Basically, I'm trying to justify the cost of front A-arms.
If I can get my camber close to spec (with stock arms), then I obviously don't need aftermarket arms. But if my camber will be way out of spec, then it'd be better for me to buy the arms rather than chewing through tires.
I could get my car aligned now and see what my camber is at, but like I said, I don't want to risk having to pay for 2 alignments.
James1990
Dec 16, 2015 08:57 PM
Vigman
Nov 17, 2015 04:34 AM
DarkCreep
Oct 17, 2015 11:50 PM
emooheo
Oct 14, 2015 08:58 AM
Mw870
Sep 10, 2015 07:50 PM
