19rear&18front
Old May 12, 2005 | 03:10 AM
froggy's Avatar
froggy
Default 19rear&18front
Is it a good compromise(look-performance-price-confort-handling)?
Looking for Kosei k3,new lightweight rims 19/8.5 rear(18lbs:8.2kg)+Toyo t1r 255/40/19 & 18/8.5 front(15lbs:6.9kg)+245/40/18
offset 35 all around with rear spacers(20mm)
I've been calculating(Tire size calculator),it's ok. Approximately same sidewalls height front/rear : cool. tcs/vdc should be fine,less understeer,same steering response,approx same braking distance,performance...won't loose too much i guess
Am i missing something? Good compromise? I'll get the Hotckis tvs kit next
(i have the 18 performance)
Thanks sharing your opinions/advices
Old May 12, 2005 | 04:58 PM
twenzel's Avatar
twenzel
Its a good light weight wheel. But it seems its designed for front wheel drive cars. You could go with spacers. Its up to you. I think it would look funny though.
__________________
optimumarc
Apr 17, 2008 08:50 PM
fordslowcus
Mar 7, 2007 12:51 PM
jdm_Z33
Feb 27, 2006 11:48 AM
