any problems with running spacers on 17"s?
Old Nov 27, 2002 | 06:06 PM
roberto350z's Avatar
roberto350z
Default any problems with running spacers on 17"s?
I need my rims just a hair out more. Im thinking 8mm should be good...... do I run the risk of damaging suspension geometry? tire wear?
Old Nov 28, 2002 | 06:42 PM
N74DV's Avatar
N74DV
you can run up to 5/16" on the rear but the fronts you can;t run anything over 1/8"
I tried.... the front studs are shorter than the rear.
I ended up having to have a custom set of billet spacers made with thier own studs. My wheels are now just about flush with the body... huge improvement.
wheelspacers.com has more info
Old Nov 28, 2002 | 10:37 PM
roberto350z
are we talking about factory rims or the rims pictured on your signature?
Old Nov 28, 2002 | 11:21 PM
N74DV's Avatar
N74DV
makes no difference really. The front studs are only long enough to put the wheel on... factory or aftermarket.....
I tried to put a 1/4" spacer up front and was only able to get 2 turns on the lug nut.
Uriyo_
Sep 8, 2021 08:46 AM
