G2 Caliper Paint?
Old May 31, 2005 | 09:34 PM
EvL350Z's Avatar
EvL350Z
Default G2 Caliper Paint?
Sup guys...has anyone used this before?...is it hard?...do you have to disconnect any brake lines from the caliper?...any tips just ordered...THANKS
Old Jun 1, 2005 | 04:54 AM
King Tut's Avatar
King Tut
Since you got a nice brush on kit there is no reason to remove the caliper. You can just pull the pads and paint the caliper on the rotor.
Old Jun 1, 2005 | 05:35 AM
brendone's Avatar
brendone
Like King Tut said. It's pretty easy to paint while still on the car, just pull out the pads. Saves you bleeding the system when you put everything back on.
Old Jun 1, 2005 | 10:01 AM
sq40's Avatar
sq40
I tried the Dupli-Color Kit out. Very Nice Finish and Quality Look.
Took about 12 Hours to do:
Remove Drivers Side Wheels, Remove Brake Pads,
Paint Calipers with Brush.
Repeat Paint every 15-20 Minutes.
After 10 Coats, Let dry for 1 Hour.
Re-Assemble.
We let them dry for 24 Hours without driving the car, then
started on the other Side. Let it dry for 24 Hours and then Gave
it the test drive.
Kit came with everything but a tooth brush, (Cleaner, Paint, Brush, Stir, Mask) for $14.99 at advance auto.
Old Jun 1, 2005 | 10:17 AM
bixby's Avatar
bixby
Buy a small Artist brush. the one that comes in the kit is just a bit to big to reach those tight areas without getting paint where you don't want it.
Old Jun 1, 2005 | 06:30 PM
sq40's Avatar
sq40
Another Good Trick,
Wrap a Paper Towel around your Rotor and then rotate it under the entire caliper. makes a perfect mask.
ETA: Here are my Results with Duplicolor;
Old Jun 1, 2005 | 06:37 PM
geez zee's Avatar
geez zee
Thumbs up
I have used the G2 caliper paint... it is a very good product. The color that I used (red) did not change over time (just over a year), or if it did 'color shift' a bit, the change was too small to be noticable.
I agree that you will need to buy an 'artist brush' (the one that comes with the kit is pretty lousy!). Get one about 3/8" wide; flat tipped.
Don't disconnect anything; just take your time.
Old Jun 1, 2005 | 11:59 PM
Beaker02's Avatar
Beaker02
Yep. EZ. A fun DIY Project.
Old Jun 2, 2005 | 10:33 AM
backagain's Avatar
backagain
here is a link to a page i just made, it has pics of me painting my calipers with a brush kit. very easy to do, little tip for removing the brake pad, on the backside of the caliper, there are 2 bolts, one at the top and one at the bottom, remove only the one at the bottom and slide out the bolt, then flip up the caliper and remove the brake pad, you do not have to take off both bolts.
http://www.panhandlez.com/calipers/calipers.html
Old Jun 2, 2005 | 12:46 PM
sq40's Avatar
sq40
Dude.. You Painted your PADS!?!
Old Jun 2, 2005 | 01:01 PM
backagain's Avatar
backagain
hahaha.....no, look to see where i taped it up, only the exposed part was painted, not the pad itself.
Old Jun 2, 2005 | 01:33 PM
sq40's Avatar
sq40
You had me skeered there for a minute..
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
Cashwin
Oct 1, 2015 06:36 AM
