wheel spacers???
Old Jun 3, 2005 | 03:43 AM
Chad68's Avatar
Chad68
Default wheel spacers???
Anybody know off hand what the widest wheel spacer size is that can be safely used?
Will a 1/2" spacer work with stock lugs and asuming of course you have fender clearance?
Thought I once read that a 3/4" spacer was the widest that can be used on the Z but that seems like an awful thick spacer to me to be safe especially using stock bolts and lugs.
Thanks
Old Jun 3, 2005 | 05:28 AM
Chicken's Avatar
Chicken
I'm not sure you realize how the spacers go on. They generally include longer stud bolts. I don't know the widest spacer that can be used (also they're sold in mm, not inches and I was looking at 15-20mm rear for my car). Best option is to try to buy the wheels with the correct offset in the first place (which I thought I did, but there seems to be a bit of room which I'm not completely happy about).
Old Jun 3, 2005 | 09:20 AM
anotheraznguy's Avatar
anotheraznguy
how much are you trying to go.. usually 5mm is generally the longest to go w/ stock lugs
but they do offer bolt on spacers that go from 15-30mm.
Old Jun 4, 2005 | 01:37 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
even if you put on a 5mm spacer you will have to upgrade to longer hub bolts...
H&R Spacers include longer hub bolts...
TEhy are availble in 5mm, 15mm, 20mm, 25mm...
http://performancenissanparts.com/ca...roducts_id=385
Old Jun 5, 2005 | 01:15 AM
froggy's Avatar
froggy
Jason,i'd like to know if longer hub bolts are hard to install -- do i need to remove original hub bolts(for DRS type 15+20) -- compared to DRM type 25 which are easy since hub bolts are already fixed on the 25 spacer ?
Thanks
Old Jun 5, 2005 | 04:50 PM
Jason@Performance
Performance Nissan
yes you have to remove the original bolts for DRS Spacers...
You have to remove the caliper, rotor, tap out each wheel stud... pull the new ones in... and then you are set...
Old Jun 6, 2005 | 09:48 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Jason if I get wheels with a + 38mm offset what spacers would I need to keep them NOT tucked in but looking agressive. I am gonna run staggered 18x8 & 18x9 rears....Thanks also good talking to you Sat at the dealer thanks..
Old Jun 7, 2005 | 09:18 AM
anotheraznguy
you would need to get like a 25mm spacer front and rear =)
Old Jun 7, 2005 | 01:09 PM
Jason@Performance
Performance Nissan
if it is
18x8 +38mm you should get a 15mm spacer...
18x9 +38mm you should get a 15mm spacer...
You could do 20mm but then you would have to do some fender rolling in the rear depending on your height...
Obadabot
Jun 18, 2023 11:31 PM
