Will a 275/30/20 tire on a 9" wide et 28 wheel fit the front???
Old Jun 27, 2005 | 04:55 PM
Roggan's Avatar
Roggan
Exclamation Will a 275/30/20 tire on a 9" wide et 28 wheel fit the front???
I am buying tires for my new wheels hopefully tomorrow, i want to go with a non staggered setup as i want o have a more oversteer biased balance, so the plan is to fit 275's around. I have heard some having small rubbing problems with 275 and other say its ok...
Wheels (front)
Diameter: 20"
Width: 9"
Offset: 28mm
Tires
Brand: Continental ContiSport contact 2
Dim: 275/30/20 (26.5" diameter)
QUESTION:
Will the wheel/tire combination fit the front without rubbing during HARD (track) driving and full lock?
My Z currently runs on stock suspension
Thanks in advance for your help guys
/Roger
Old Jun 27, 2005 | 06:35 PM
SickG35's Avatar
SickG35
it fits no problem. I was running 19x9 with 275/30 and my car was very low with coilovers.
Old Jun 27, 2005 | 10:45 PM
Roggan's Avatar
Roggan
Thanks SickG35
What tires did you use?
Toyos are usually narrower for the same dimension then other brands, the Continental's (German tires) are pretty much neutral, not larger or smaller then average. Dunlops and Goodyear are usually wider etc
I guess its hard to tell, but was there resonable margin as well? Your tires will be 1" less diameter then mine as well, i hope that wont eat up the margins...
/Roger
Old Jun 28, 2005 | 03:19 AM
SickG35's Avatar
SickG35
I used Yokohama AVS.
Old Jun 28, 2005 | 04:15 PM
de_only_Z_2_c's Avatar
de_only_Z_2_c
no problem i work at a wheel shop
416blueZ
Jun 11, 2024 10:56 AM
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
kyin
Oct 15, 2015 05:54 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
