Gram Lights 57S on Track Model
Old Jul 7, 2005 | 08:49 PM
mena661's Avatar
mena661
Default Gram Lights 57S on Track Model
Anyone have the following setup on a Track Model? 18x9.5" at all 4 corners with a +30 offset. What's the brake clearance like? Thanks.
Old Jul 8, 2005 | 06:26 PM
mena661's Avatar
mena661
I talked to Tirerack and was told that these wheels in this size and offset won't clear the front Brembo's. Of course, he didn't tell me if another offset would work.
Old Jul 8, 2005 | 08:23 PM
MY350Z.COM's Avatar
the 18x9.5 57S is available in a +22 offset. Why not run that instead. or if you opt for that offset, get some 10mm spacers.
ask our volk dealers, they will know.
Old Jul 9, 2005 | 09:14 AM
mena661's Avatar
mena661
The reason why I chose +30 is that I want to run the same size tires (265/40R-18) all around and want the ability to rotate them as well. If +22 will work on all four corners and clear the Brembo's then that works for me. But like you suggested I'll contact the Volk dealers here and ask them.
Old Jul 9, 2005 | 09:21 AM
MY350Z.COM's Avatar
Ohh I see what you are doing now. The rears will surely fit, you may need to run a 5-10mm spacer up front.
You can take some measurements yourself and get somewhat an idea of where your wheel is going to sit.
http://toy4two.home.mindspring.com/input.html
http://www.miata.net/garage/tirecalc.html
Old Jul 9, 2005 | 09:29 AM
mena661's Avatar
mena661
Thanks much Mike. With a 100mm spacer up front the offset goes to +40 or +20?
Old Jul 9, 2005 | 09:32 AM
MY350Z.COM's Avatar
I hope you are kidding, hhehehe.
Old Jul 9, 2005 | 09:33 AM
mena661's Avatar
mena661
Oops. I meant 10. I'll check out the offset calculator.
Old Jul 9, 2005 | 09:42 AM
MY350Z.COM's Avatar
Spacers lower your offset.
So on this wheel being +30, a 10mm spacer would effectively bring your offset down to +20.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
