WILL TPMS FIT ON 19" SF CHALLENGE?
Old Jul 21, 2005 | 11:24 AM
MOJIISWES's Avatar
MOJIISWES
Default WILL TPMS FIT ON 19" SF CHALLENGE?
If they dont then where can I get the banding for the rims? And I tried a search and found no results. Any help would be appreciated. My tires and wheels are being installed on tuesday 7-26-05. Thanks in advance.
Old Jul 21, 2005 | 12:18 PM
autois4pussies's Avatar
autois4pussies
You have to band. There is no way you did a search and found nothing.
Try searching for 'banding'. Theres a bunch of stuff including do it yourself stuff.
btw im doing the same exact thing and getting mine installed tuesday :].
Old Jul 21, 2005 | 01:49 PM
ssc's Avatar
ssc
yep, u need bands for sf-challenge
Old Jul 22, 2005 | 05:53 AM
wtf no turbo's Avatar
wtf no turbo
I dont think the tps work on any multi piece wheel.None that i have seen anyway.
Old Jul 22, 2005 | 10:54 AM
autois4pussies
ya usually only works with1 piece. If its two or more u wont be able to because this is how it attatches to 1 piece wheels like our stock wheels:
https://my350z.com/forum/attachment....chmentid=11087
The tps litterally becomes the valve stem aswell. With multipiece wheels there is usually a 90 degree bend which the tps can not do because its completely straight.
Old Jul 22, 2005 | 12:51 PM
arcada's Avatar
arcada
You can also mount the TPS/Valve Stem vertical in the wheel barrell.
It won't clear 14" bbk's though.
350z82
Oct 1, 2015 06:25 PM
