Need a recomendation on Tires
Old Aug 26, 2005 | 06:42 AM
ZPirate's Avatar
ZPirate
Goodyear Eagle F1 GS D3s or Michelin Pilot Sport PS2s.
Old Sep 2, 2005 | 01:37 PM
fisherprice's Avatar
fisherprice
I ended up going with the bfgoodrich kdw2's. They are awesome.
Old Sep 4, 2005 | 06:45 PM
Default There are more than 500 “best tire” posts.
If you're happy with the tires which you currently have, why not buy another set?
Old Sep 4, 2005 | 07:07 PM
Default This is a good question for one of the racing forums.
Originally Posted by Bubble
isn't the bigger the tire, the harder for "cornering"?
Every tire and wheel combination is a compromise. Wider tires means wider wheels means more weight which is bad.
Comparing a 8-inch tire on a 8-inch wheel, and the same brand 9-inch tire on the same 9-inch wheel, the 9-inch tire will allow more g’s in the corner before breaking traction.
The problem is that when you go for a wider tire, you usually select a lower profile tire. The sidewall of a 50-series tire will “flex” more that the sidewall of a 30-series. The additional “flex” gives you some addition “stick” before the tire breaks traction.
Humble opinion and all that polite stuff.
Have you ran or watched autocross? Count the number of cars running 30 series tires as compared to those running 50 series?
Old Sep 4, 2005 | 08:38 PM
Scrapin 240's Avatar
Scrapin 240
Definitely do not get the Toyo T1-Rs no matter what you do. They are terrible.
Old Sep 5, 2005 | 08:13 AM
visionboy's Avatar
visionboy
+1, worse than my stocks
Old Sep 5, 2005 | 09:47 AM
Bigmikeny21's Avatar
Bigmikeny21
Eagle F1
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
