Lowering Z eliminates feathering?
i've tried to search through all of the feathering posts and have read different things, i am looking to purchase an 03 and was wondering if i lowered the car with a set of say eibach springs, would that correct the feathering problems the Z experiences? Is there anything that could be done to correct this problem? aftermarket or not? Bc im thinking about the Z but don't want all these headaches
I didn't have feathering until I got my Nismo S-tune suspension and they realigned it to the new, "corrected" alignment specs after the install, and two weeks after the install.
Originally Posted by thrill350z
so is there anything that can be done to correct this for good?
I have just had a Eibach Pro kit installed and there is plenty of adjustability in the stock set up; however should you wish to lower the car more than an inch or so you will more than likely run out of adjustability and therefore will require camber kits etc.
Also remember that an alignment can be thrown out very quickly by hitting a large pot hole or similar. My Z is only 7 months old, has no sign of feathering but the alignment front and rear was out by the proverbial mile!
Hope this helps.
