10.5" Axis Hiro in the rear or 9.5"?
Old Aug 19, 2005 | 09:13 AM
boma's Avatar
boma
Default 10.5" Axis Hiro in the rear or 9.5"?
I can get either at almost the same price. Which is better?
I do not want to rub.
Old Aug 19, 2005 | 09:14 AM
AZ350Z's Avatar
AZ350Z
10.5 with 275 tire will not rub. Looks better.
southern_info's Avatar
southern_info
wider is better for traction and appearance!!!
Old Aug 19, 2005 | 09:41 AM
King Tut's Avatar
King Tut
Wider is heavier and looks stupid if you are only going to stick a 275 on it which will fit easily on a 9.5".
Old Aug 19, 2005 | 01:34 PM
Triple8Sol's Avatar
Triple8Sol
10.5 with a 275 looks badass
Old Aug 19, 2005 | 01:48 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
10.5 all the way.
Old Dec 7, 2005 | 04:40 AM
trescincuenta's Avatar
trescincuenta
The 9.5 has a little over 2" lip, the 10.5 has a little over 3" lip. The weight of the 8.5 , 9.5 and 10.5 are all within a 1 lb diff of each other
Old Dec 7, 2005 | 11:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If your gonna do it correctly, do the 10.5" with a 285 or larger. 275 on a 10.5" looks stupid, and makes the sidewall stretch-I guess some members like that mid 80's VW Golf stretched rim look If you want to run 275's then the 9.5" will be just fine....
Old Dec 7, 2005 | 12:14 PM
Nexx's Avatar
Nexx
owned!
btw. if you go with BFG KDW-2 in a 275 it will not have that much of a stretched look cause they have a bit more sidewall then toyos plus they look badass. the 10.5 will also look much more flush with your fenders then the 9.5 giving it a more wide aggressive look. i debated this but I trusted what Chris at F1 told me. He said the 10.5" looked soooo much better then a 9.5" wheel. If you ever resale your wheels the 10.5's would be a bit more desirable to most people.
Old Dec 7, 2005 | 12:16 PM
Nexx's Avatar
Nexx
oh another thing, you might wanna give Chris at F1 a call. You might be able to pick up a set of Volks for not that much more then your paying for your hiro's. They are running a blowout sale on their inventory. I just got a set of DB GT7's from him.
Old Dec 7, 2005 | 07:23 PM
lascala26's Avatar
lascala26
9.5"...no doubt...for 275.
Old Dec 8, 2005 | 02:38 AM
Chad68's Avatar
Chad68
Well you're half right.
It looks bad.
It looks like ***.
35reilly
Sep 28, 2015 07:42 AM
