Widest wheel
Old Sep 1, 2005 | 06:38 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
the part of the spoke just above the hub mount of the wheel does not clear...
it doesnt clear the lowest part of the brakes... pleanty of clearance up top...
Old Sep 2, 2005 | 10:44 AM
barthelb's Avatar
barthelb
Master
I think I see what you are talking about, you want a setup where the rear is wider and has a big lip. Kinda like this?
Originally Posted by w8lifter21
This is going to be difficult to explain with out pics but here goes. What kind of offset is it when it looks like the center portion of the wheel is "recessed" when compared to the rest of the wheel? A friend of mine that has a 240sx set up for drifting and he is running a stretched 215 wide tire on his 5zigen wheel. It looks like the center part of the wheel where the lug nuts go on is set real far back in the wheel. Tough to explain I know.....maybe i'll try and get a pic next time I see him
Old Sep 2, 2005 | 03:44 PM
w8lifter21's Avatar
w8lifter21
That's definetly hot, but not quite what I am trying to describe. Basically take that wheel, leave the hub mounting point in the same position, but pull the spokes out to the edge of the rim, eleminating the lip. I'm still searching for a pic.....
Old Sep 2, 2005 | 04:36 PM
Zexy's Avatar
Zexy
^ Hawt!
Old Sep 2, 2005 | 10:39 PM
JDMFairlady21's Avatar
JDMFairlady21
that silver Z has hyper 5zr wheels rite?
Old Sep 3, 2005 | 04:28 PM
w8lifter21's Avatar
w8lifter21
Ok, I don't have a pic but I did talk to the guy with the drift 240. He said that he is running a 17x9 in front and 17x10 in the back. He has a +15 offset in the front and a +12 in the rear I think he said. Anyone know if that sounds like it would fit?
Old Sep 3, 2005 | 04:31 PM
Nano's Avatar
Nano
wildest wheel is any wheel that fits 14" brakes
Old Sep 6, 2005 | 02:20 PM
barthelb's Avatar
barthelb
Master
Yes with the Super Metallic black finish.
Old Sep 6, 2005 | 04:35 PM
JDMFairlady21
thanks man... too bad those wheels dont have much aggresive offsets available though.
Old Sep 8, 2005 | 07:44 AM
w8lifter21's Avatar
w8lifter21
So far the wides tire I have seen on a Z is a 275. Anyone running a wider tire or have a pics? At what width does the wheel start to poke out from the fenders front and rear?
Old Sep 8, 2005 | 07:50 AM
Jason@Performance
Performance Nissan
295/35/18
stock car no fender modifications same set up...
Old Sep 8, 2005 | 08:00 AM
w8lifter21's Avatar
w8lifter21
Is that a 295 tire on a 10.5" wheel? What's up front?
Old Sep 8, 2005 | 08:04 AM
Jason@Performance
Performance Nissan
yes...
18x9.5 265/35/18
18x10.5 295/35/18
Old Sep 8, 2005 | 11:07 AM
TriX's Avatar
TriX
jason you repainted your car?
you have more pics?
Old Sep 8, 2005 | 11:29 AM
Jason@Performance
Performance Nissan
http://photobucket.com/albums/v461/P...MO/PERF082405/
Old Sep 8, 2005 | 07:10 PM
Srivero297's Avatar
Srivero297
Alright-- this is another "how wide" question, but I already have my rims and may just need to get some new rubber.
First off, theyre 20" Volk GT-C. 8.5 front, 10.5 rear.
im toying with the idea of putting 9.5 in the front in place of the 8.5, if it will fit.
current tires: 245/35/20 front, 275/30/20 rear
suspension: currently stock, but have Tein FLEX on the way
problems: 1) the 275s are really stretched on the 10.5" rim, but when I bought them Brian at 350zonline told me 285s would rub, so thats why I stuck w/ 275. 2) Like I said, Id prefer the 9.5 in the front, but Brian also told me the 9.5 would rub and the 8.5 wouldnt, so thats why I havent done it yet.
questions:
1) will anything wider than 275/30/20 rub in the rear?
2) will the 9.5" fronts rub in the front?
3) whats the biggest tire I can put on 10.5" rim?
4) if i do need to modify the rear fenders to fit a bigger tire, what/how would I need to modify it, and how much bigger of a tire could I fit?
5) same question as #4, but for the front fenders?
thank you to whoever responds in advance
Old Sep 11, 2005 | 03:36 PM
Srivero297's Avatar
Srivero297
bump ... ??
Old Sep 11, 2005 | 03:56 PM
  #38
zman2's Avatar
zman2
Originally Posted by Jason@Performance
yes...
18x9.5 265/35/18
18x10.5 295/35/18
Jason:
What are the offset of these wheels?
RPF1's ?
Thanks
Old Sep 11, 2005 | 04:25 PM
  #39
mikedZ33's Avatar
mikedZ33
Originally Posted by zman2
Jason:
RPF1's ?
Thanks
Also, what is the weight of RPF1's in 18x9.5/18x10.5?
Thanks.
Old Sep 11, 2005 | 05:25 PM
  #40
Jason@Performance
Performance Nissan
My wheels are NT03+M
+27 front
+30 rear
RPF1's are +15mm rear on the 10.5 and +15mm 9.5... you could do it.. but would have to run your tires stretched...
