Technical Info - Wheels & Tires
Old Dec 13, 2002 | 09:25 AM
veilside z's Avatar
veilside z
Post Technical Info - Wheels & Tires
This is a basic update on the factory fit sizes for those of you interested in swapping out your rims (rpm=revolutions per mile):
17"x7.5J +30 225/50WR17 = Standard 17" Front (rpm=780.0)
17"x8.0J +33 235/50WR17 = Standard 17" Rear (rpm=768.0)
18"x7.5J +30 225/45WR18 = Standard 18" Front (rpm=777.0)
18"x8.0J +30 245/45WR18 = Standard 18" Rear (rpm=756.0)
18"x8.0J +30 225/45WR18 = Rays 18" Front (rpm=777.0) 8.1kg
18"x8.5J +33 245/45WR18 = Rays 18" Rear (rpm=756.0) 8.3kg
All wheels are 5 hole with 114.3mm P.C.D.
Popular aftermarket fitments
Volks TE37 18" setup ( http://www.rayswheels.co.jp/ )
18"x8.5J +22 245/40R18 = Volks 18" Front (rpm=784.0)
18"x9.5J +22 275/40R18 = Volks 18" Rear (rpm=756.0)
Volks TE37 19" setup ( http://www.rayswheels.co.jp/ )
19"x8.5J +22 245/35R19 = Volks 19" Front (rpm=783.0)
19"x9.5J +22 275/35R19 = Volks 19" Rear (rpm=759.0)
Nismo GT4 18" setup ( http://www.nismo.co.jp/ )
18"x8.5J +25 245/40R18 = Nismo 18" Front (rpm=784.0) 8.2kg
18"x9.5J +25 275/40R18 = Nismo 18" Rear (rpm=756.0) 8.6kg
Other aftermarket fitments
SSR GT3 19" setup ( https://my350z.com/forum/showthread....threadid=12525 )
19"x8.5J +37 245/35R19 = SSR 19" Front (rpm=783.0)
19"x10.0J +41 275/35R19 = SSR 19" Rear (rpm=759.0)
BBS LM 18" setup ( http://www.bbs-japan.co.jp )
18"x9.0J +25 245/40R18 = BBS Type 194 18" Front (rpm=784.0) 8.2kg
18"x10.0J +25 275/40R18 = BBS Type 195 18" Rear (rpm=756.0) 8.6kg
BBS LM 19" setup ( http://www.bbs-japan.co.jp )
19"x9.0J +18 245/35R19 = BBS Type 196 19" Front (rpm=783.0)
19"x10.0J +22 275/35R19 = BBS Type 197 19" Rear (rpm=759.0)
Fluctuations in the rolling radius are an everyday occurence (even with pressure monitors).
All speedos are innacurate by some degree - a speedo that reads true at 30mph will not be true at 70mph & vice versa.
As long as you are there or there abouts everything will be fine.
If swapping out aim for somewhere near original, but don't be too much of a stickler for the exact match
F = 775.0 to 784.0
R = 754.0 to 768.0
Also, don’t forget that the offset figure refers to the offset of the mounting surface & does not determine the clearance for brake calipers & suspension parts. This clearance dimension will depend on the specific wheel design & any modifications made to the vehicle suspension & brake setup.
If anyone else has tech info relating to specific brands & ACTUAL setups please post.
Please no photoshops, or wishlists - this stuff needs to work on the vehicle - get my drift???
Keep it positive…
Obadabot
Jun 18, 2023 11:31 PM
