18x10.5 +13
Old Aug 28, 2005 | 05:19 PM
smellslikecurry's Avatar
smellslikecurry
Default 18x10.5 +13
ront is +21 9.0" with 225/40/18 falken 512's
rear 10.5" +13 offset w/ 265/35/18 falken 512's
will those fit
Old Aug 28, 2005 | 05:27 PM
Zexy's Avatar
Zexy
With your fenders rolled you should be fine. This is MY opinion.
Old Aug 28, 2005 | 05:28 PM
JETPILOT's Avatar
JETPILOT
Front might on a non lowered vehicle. Rear no way. 10.5 +22 is the lowest practical offset you can go with.
Respect
JET
Old Aug 28, 2005 | 05:35 PM
ppw350Zunit's Avatar
ppw350Zunit
+1
Old Aug 28, 2005 | 05:47 PM
Zexy's Avatar
Zexy
Respect
JET
I highly disagree. It will fit if the fenders are rolled.
Old Aug 28, 2005 | 05:51 PM
JETPILOT's Avatar
JETPILOT
10.5 + 13 ????? I'd have to see that to believe it. You're going to have to provide some credible proof as in pics or posts here that a 10.5 +13 will work. I had a 10.5 +22, and that was the limit. There wasn't another 1cm of room. I am lowered 1 1/4 in the rear.
Respect
JET
Old Aug 28, 2005 | 06:57 PM
Zexy's Avatar
Zexy
Well like he said he has a 265 tire.
Rim manufacturers are different, your fenders are not rolled, and camber also affects fitment. You just can't just jump straight into an assumption.
Don't get me wrong..It's a tight fit but it'll be fine with that tire.
smellslikecurry, what wheels are they by the way?
Old Aug 28, 2005 | 07:55 PM
JETPILOT's Avatar
JETPILOT
265 tire or not.... it still wouldn't work. It doesn't matter who manufacturers the rim. Offset is offset. How do you know if my fenders are rolled or not???? BTW they are rolled. 10.5 +22 wouldn't fit withpout rolling. Show me a 10.5" +13 on a Z? It can't be done.
In regard to tire size which no one has adressed. a 225 on a 9.0 rim won't work, and neither will a 265 on a 10.5. This whole setup sucks and has no business on the Z.
Respect
JET
Old Aug 28, 2005 | 08:17 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Zexy is right!
LMAO! I have seen 20x11 with a 17 offset on the rear of a Z with stock fenders! Dunlops and Falkens will give you more clearance since their sidewall designs seem to collapse more. I run 19x11 on my car with no problems and my bumper is 2 inches from the ground.
Believe it or not, the rim being made by a different rim company will make a difference since there are different disks that are used to maximize lip and clearance
Here is the pic of the 20's I was talking about
PROOFFFFF!!!!!!!
Old Aug 28, 2005 | 08:24 PM
MY350Z.COM's Avatar
Damn that's a clean ride. NICE!
Old Aug 29, 2005 | 04:17 AM
smellslikecurry
work vsxx
Old Aug 29, 2005 | 07:59 AM
JETPILOT's Avatar
JETPILOT
Damn !!!! I hate bing wrong. If I didn't see it I wouldn't have believed it. U have no rubbing?
Respect
JET
Old Aug 29, 2005 | 09:04 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Respect
JET
Don't worry about it man. We are all here to learn from one another to take our vehicles to the next level. The pics i provided above are from the sponsored Z from Speed Alliance. It has cut fenders inside, which is basically an aggressive roll I have a 19x11 with a rolled fender and it fits just fine.
Old Aug 29, 2005 | 06:03 PM
drumma022's Avatar
drumma022
Proof + Pics and actual offset #'s.
I have not rolled the fender one bit and it fits when slammed.
19x9.5 +11 235/35/19
19x10.5 +11 265/30/19
stfuad
Old Aug 29, 2005 | 06:12 PM
drumma022's Avatar
drumma022
RICKDOGG - you always post wheel sizing, but not offset #'s! What is the offset on your x11's!??
Old Aug 29, 2005 | 06:35 PM
Zexy's Avatar
Zexy
I rest my case JETPILOT.
Old Aug 29, 2005 | 06:39 PM
JETPILOT's Avatar
JETPILOT
I checked out your other pics on this thread you posted https://my350z.com/forum/wheels-and-tires/138338-sf-chal-11-slammed-on-stock-fenders.html .
What you failed to tell us is that you have at least negative 4 degrees of camber !!
It's my opinion that "fitting" means at normal camber settings. 1-2.5 degrees.
If you put on the right size tires on the car we wouldn't be having this conversation. 235/35 on a 9.5 wide rim and 265/30 on a 10.5 wheel is too narrow. The tire is stretched. The aspect ratios and rolling diameters are incorrect as well. The rolling diameter is smaller than stock.
Sooooo my definition of fitting is way different than yours.
Respect
JET
Old Aug 29, 2005 | 06:58 PM
JDMFairlady21's Avatar
JDMFairlady21
i think JETPILOT and everyone else is looking at this issue in two different ways. in regards to JET's responses- i think you are talking about more towards what is more realistic and somewhat practical and correct when it comes to tire aspects and rolling diameters, more like on the books settings, no offense.
everyone else, inlcuding me is more on the make it fit attitude like my fellow drifters from zilvia.net, forget practicality and correct camber and such, make it fit and do whatever to accomplish which includes fender mods, lots and lots of camber, and suspension mods. so i believe everyone has a valid point to an extent. now it all depends if the owner of the rims wants to go through that or stick to whats commonly fitted. rest my case.
Old Aug 29, 2005 | 07:07 PM
JETPILOT's Avatar
JETPILOT
I agree.... this is a case of mild or wild.
Respect
JET
Old Aug 29, 2005 | 07:10 PM
JDMFairlady21
damn all that typing and i couldve just said that! hehe
