New way to mount TPS sensors to 2 or 3 piece wheels...
I found this on another site. The guy used the mounting hole for the wheel manufacturer's valve stem to secure a bracket into which the tps screws. As any one else seen this before? Where would you get that bracket? These seems like a much better method than banding the tps sensor to the wheel...
http://www.everything350z.com/ubbthr...p?Number=13860
When I asked Chris at F1Motorsports if he could install TPS to my new wheels, he said yes, but he has to drill a hole.
I'm not sure what he was talking about, but once my rims come in, I will update you on what specifically he plans to do to install them.
I know this is an old post but has anyone heard an update on this?!? This seems like a great idea and that custom bracket looks like a clean job and more secure than past ideas I have run into.
Originally Posted by THE TECH
Drilling a hole in the wheel is both no good and will void any sort of warranty with the wheel mfg.
Look again. You don't have to drill a hole in the wheel. You use the existing valve stem hole to secure the bracket. Thats what makes this so ingenious...
Originally Posted by 3five0_GT
You have to buy a wheel with the valve hole in the center of the rim. Banding will work on any wheel.
David C.
