Is this offset ok?
20 x 9 front +37mm
20 x 10 rear +38mm
What kind of tire size would I need for these? Is the offset ok for an '05 Z? Also, I have an Eibach Pro Kit on the way to me. Would I rub at all with this drop and this size rim?
20 x 10 rear +38mm
Originally Posted by CompiledMonkey
20 x 9 front +37mm
20 x 10 rear +38mm
20 x 10 rear +38mm
Instead of guessing, how about using a offset calculator?
http://www.1010tires.com/WheelOffsetCalculator.asp
I concur. Offset calculators are the best.
Take measurements
Calculate
Take measurements
Calculate
Take measurements
Calculate
Sometime's it's also better to input your tire width if you are going with oversized race tires. Since that will be the widest point rather than your wheel.
Take measurements
Calculate
Take measurements
Calculate
Take measurements
Calculate
seagrasser
Oct 11, 2015 03:27 PM
