Oversteer Problem
Old Sep 4, 2005 | 12:33 PM
Scrapin 240's Avatar
Scrapin 240
Default Oversteer Problem
Hi Everyone,
I just swithced over the rear to 245/45 18 Toyo T1-R's and the fronts are still the factory RE040. the rear oversteers a lot now and even kicks in the VDC,and it tracks the road very bad now. Is this because of the two different brands or is that how the T1-Rs are?
Thanks in advance.
Old Sep 4, 2005 | 01:21 PM
visionboy's Avatar
visionboy
Originally Posted by Scrapin 240
Hi Everyone,
Thanks in advance.
IMO it's the T1-R. I have the same tires and handling (oversteer )
is much worse than my stock tires. Can't wait till these wear out so I can get new ones.
Old Sep 4, 2005 | 03:36 PM
Scrapin 240
i am surprise they SUCK so much. I've heard so many good things about them and here they are HORRIBLE tires. the old t1-s were much better then, and its sad to say that the RE040 are better who would have thought that
Old Sep 4, 2005 | 03:55 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you have too much oversteer, can't you just install a stiffer front sway bar? Someone else with some more experience may be able to confirm this...
Old Sep 4, 2005 | 06:29 PM
If your driving technique is the same, its the rear tires.
Old Sep 4, 2005 | 10:56 PM
froggy's Avatar
froggy
Toyo T1R need a brake in period of 300 miles to grip a lot
Old Sep 5, 2005 | 07:34 AM
visionboy's Avatar
visionboy
I have about 1000 on mine. Grip yes, Mushy steering yes
Old Sep 5, 2005 | 10:08 AM
Road Warrior's Avatar
Road Warrior
upgrade your suspension to help with the upgraded tires...sway bars, coilovers...etc
Old Sep 5, 2005 | 06:39 PM
Scrapin 240
these tires feel more like a downgrade =(
Old Sep 6, 2005 | 02:36 PM
Sorry about the tires. Suspension modifications aren't going to make the tires better, they’re just going to “balance” the car. Lets say that the tires cost $300, and you're on a tight budget. Grin and bare for 15,000 miles, then toss the Toyo’s in the trash.
Old Sep 6, 2005 | 02:56 PM
Chris@DTD's Avatar
Chris@DTD
What are you running for air pressure in the Toyos?
Old Sep 6, 2005 | 03:25 PM
visionboy's Avatar
visionboy
last time i checked, it was around 38
what are your reccomendations and should it be different front and back?
Old Sep 6, 2005 | 03:48 PM
Scrapin 240
i run factory psi setting 35 all around
Old Sep 7, 2005 | 04:24 PM
Road Warrior
the only way to get any kind of adjustment is by changing out suspension components. tires are not going to solve any of your oversteer problems thats for sure. no matter how high grade of tire you get you are still limited by the stock suspension. imo, i would rather spend my money on suspension than any other modification as far as the z goes....seems like that is the weakest link of the car.
coilovers, sway bars and camber components would be the best option but there are other alternatives that are cheaper if your on a budget. i have all of the aforementioned upgrades and i am still on stock tires....but my car handles great. i can adjust height, ride stiffness, understeer and oversteer as necessary and have absolutely no tire problems such as feathering or uneven wear.
good luck with your situation
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
