TOYO T1-R! The BEST Just Got Better!!!
Old Sep 13, 2005 | 08:27 AM
TXSTYLE's Avatar
TXSTYLE
Thumbs up TOYO T1-R! The BEST Just Got Better!!!
I have been a faithful TOYO customer since before the T1-S (mid-late 90's) with over 7 sets on a few different vehicles of mine. The one and only problem I have had is the 'shoulder' wearing prematurely compared with the wear of the middle. Although over the years I have consistently ran 40psi all around and the overall wear has been great! Enter the new Proxes T1-R which appear to directly address this issue... and then some! Not to mention they have FINALLY heard my wishes for a "285" in 19"!!!
Marcus (Will be ordering a set of these now for reserves!)
The new Proxes T1-R™ combines innovative Toyo T-Mode™ technology with knowledge from our participation in motorsports. Innovation through competition is the Toyo philosophy.
That translates into building a tire with optimum balance in construction and compounding to deliver the exceptional wet and dry performance you expect for many different driving conditions. The Proxes T1-R is available in 14” to 21” rim sizes and sports UTQG ratings of 280 AA A
- New "Generation S" silica-reinforced, high-grip tread compound
- New silica compound that minimizes heat build-up
- Rigid shoulder rib-bands that improve cornering
- New "Generation S" silica-reinforced tread compound with higher wet-u
- Refined V-shaped main grooves for improved resistance to aquaplaning
- T-Mode Design Technology
- Rigid shoulder rib-bands that improve response
- High-modulus bead apex rubber
- High-modulus casing (rayon or polyester depending on size)
- Wide high-tensile steel belts
- Spiral-wound, jointless edge and cap plies (construction may vary by size)
- Jointless bead wire
- High-tensile belt reinforcement cap layer (construction may vary by size)
- Spiral-wound, jointless edge and capplies (construction may vary by size)
- Rigid shoulder rib-bands that reduce irregular wear
- Rim protector
- High-dispersed silica that improves wear resistance
- Ultra-high molecular polymer that increases wear resistance
- Refined unidirectional tread pattern
- Optimized, low-profile design
- Modern sidewall styling
- V,W, and Y speed-rated (depending on size)
- UTQG Treadwear 280
- UTQG Traction AA
- UTQG Temperature A
Old Sep 13, 2005 | 08:36 AM
MY350Z.COM's Avatar
Where have you been? Haha.
Old Sep 13, 2005 | 08:39 AM
fahrenheit350's Avatar
fahrenheit350
question for ppl with T1-R's. How many miles have you been replacing these? Of course, daily driving on these. I've seen posts where they said anywhere from 15k-20k.
Old Sep 13, 2005 | 08:40 AM
seanlaw's Avatar
seanlaw
i have them and they are grrrrrrrrreat!
only about 1,000 so far
Old Sep 13, 2005 | 08:41 AM
JimRHIT's Avatar
JimRHIT
Hey Marcus .... I, like you and many others were VERY excited about these tires. However, if you search around ... initial feedback on them has been far less than good. I ended up with GY F1s instead.
Jim
Old Sep 13, 2005 | 08:42 AM
TXSTYLE's Avatar
TXSTYLE
Hey they been out that long? Couldn't be more than a couple of months...?
>>question for ppl with T1-R's. How many miles have you been replacing these? Of course, daily driving on these. I've seen posts where they said anywhere from 15k-20k.<<
I get @ 16k out of my T1-S.
Old Sep 13, 2005 | 08:50 AM
TXSTYLE's Avatar
TXSTYLE
Jim
WOW...! That is disheartening to say the least...
Marcus (Retracts that future purchase statement until further research is done.)
Old Sep 13, 2005 | 08:56 AM
MY350Z.COM's Avatar
Enough for me to say "Where you been?"
Old Sep 13, 2005 | 09:16 AM
The Brickyard Rat's Avatar
The Brickyard Rat
I've got about 3,000 miles on my T1 rs so far. Ride is definately smoother & quieter than OEM tires. Handling seems fine but I don't push the limits. We'll see on durability.
Does the UTQG 280 rating provide any clue on what milage to expect?
Old Sep 13, 2005 | 09:37 AM
visionboy's Avatar
visionboy
Well I've had these for about a month now with about 2K miles on them.
I'd advised you to do more research on them because as soon as I slapped them on, oversteer became a big problem for me. Stock tires handled much better. After 2K miles, the handling are slightly better, but much worse than i expect. YMMV
Old Sep 13, 2005 | 11:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
People opinions are either love them or hate them with the T1-S. Ive heard they are great, Ive also heard once hot they are crap, Ive heard the feel wobbly and looses on 19" rims, I dont have any personal experience with them, but Id try any tire 1X. These T1R's look nice, how much is a 285 19?
Old Sep 13, 2005 | 11:43 AM
seanlaw's Avatar
seanlaw
259 @ edgeracing.com
Old Sep 13, 2005 | 12:15 PM
Phatmitzu's Avatar
Phatmitzu
How is it compare to PS2s?
Old Sep 13, 2005 | 12:29 PM
protocav's Avatar
protocav
they are not.
i had a set of t1-s on my coupe, and replaced the worn fronts with the R's. i developed some noticeable understeer. they ae quiet and ride nice, but the grip is just not there.
the ps2's are about the best that money can buy, and the price shows it.
Chad
Old Sep 13, 2005 | 02:26 PM
311roadster's Avatar
311roadster
Default Do they make them for the stock 18" wheel?
Old Sep 13, 2005 | 02:45 PM
TXSTYLE's Avatar
TXSTYLE
235/50zr18 101y Rd 245790 6.5-7.5-8.5 27 11 27.1 9.6 12.6 1819 50 766
225/45zr18 95y Rd 246440 7.0-8.0-8.5 23 10 25.9 8.7 12.1 1521 50 802
245/45zr18 96y 245910 7.5-8.0-9.0 27 11 26.6 9.5 12.4 1565 44 781
255/45zr18 99y 245920 8.0-9.0-9.5 29 10 27.0 9.8 12.5 1709 44 769
225/40zr18 92y Rd 246010 7.5-8.0-9.0 23 10 25.1 9.1 11.8 1389 50 828
235/40zr18 95y Rd 246020 8.0-9.0-9.5 24 10 25.3 9.5 11.9 1521 50 821
245/40zr18 97y Rd 246030 8.0-9.0-9.5 26 10 25.6 9.6 12.0 1609 50 811
255/40zr18 99y Rd 246180 8.5-9.0-10.0 26 10 25.9 10.2 12.1 1709 50 801
205/35zr18 81yrd 246250 7.0-7.5-8.0 18 10 23.7 8.3 11.2 1019 50 878
215/35zr18 84w Rd 246050 7.0-8.0-8.5 19 10 23.9 8.6 11.3 1102 50 868
225/35zr18 87y Rd 246060 7.5-8.0-9.0 20 10 24.3 9.0 11.4 1201 50 857
245/35zr18 88y 246070 8.0-9.0-9.5 23 11 24.8 9.6 11.6 1235 44 839
255/35zr18 94y Rd 246080 8.5-9.0-10.0 25 10 25.0 10.1 11.7 1477 50 830
265/35zr18 97y Rd 246090 9.0-10.0-10.5 26 10 25.4 10.5 11.9 1609 50 819
275/35zr18 99y Rd 246100 9.0-10.0-11.0 27 10 25.6 10.7 11.9 1709 50 813
285/35zr18 101y Rd 246260 9.5-10.0-11.0 29 10 25.7 11.2 12.0 1819 50 807
235/30zr18 85yrd 246360 8.5 20 10 23.6 9.3 11.2 1135 50 881
245/40zr19 98y Rd 246220 8.0-9.0-9.5 26 10 26.7 9.7 12.5 1653 50 778
255/40zr19 96y 246230 8.5-9.0-10.0 28 10 27.0 10.2 12.6 1565 44 770
235/35zr19 91y Rd 246110 8.0-9.0-9.5 22 10 25.5 9.5 12.0 1356 50 814
245/35zr19 93yrd 246290 8.0-8.5-9.5 24 10 25.8 9.6 12.2 1433 50 804
255/35zr19 96y Rd 246300 8.5-9.0-10.0 25 10 26.0 10.1 12.2 1565 50 798
275/35zr19 100y Rd 246310 9.0-9.5-11.0 28 10 26.6 10.6 12.5 1764 50 782
285/35zr19 99y 246320 9.5-10.0-11.0 31 10 26.9 11.2 12.6 1709 44 774
255/30zr19 91y Rd 246460 8.5-9.0-9.5 24 10 25.1 10.0 11.9 1356 50 828
265/30zr19 93y Rd 246400 9.0-9.5-10.0 24 10 25.4 10.5 12.0 1433 50 818
275/30zr19 96y Rd 246410 9.0-9.5-10.0 26 10 25.6 10.6 12.1 1565 50 812
285/30zr19 98y Rd 246420 9.5-10.0-10.5 27 10 25.8 11.2 12.1 1653 50 806
245/35zr20 95y Rd 246330 8.0-8.5-9.5 25 10 26.8 9.6 12.6 1521 50 776
275/30zr20 97y Rd 246430 9.0-9.5-10.0 26 10 26.6 10.6 12.6 1609 50 782
295/25zr21 96y Rd 246490 10.0-10.5-11.0 30 10 27.0 11.7 12.8 1565 50 770
255/30zr21 93y Rd 246480 8.5-9.0-9.5 26 10 27.1 10.2 12.9 1433 50 767
Old Sep 13, 2005 | 05:54 PM
MY350Z.COM's Avatar
Yes
Old Sep 15, 2005 | 09:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Damn thats expensive. You can get an S03 or BGF KDWII for less, and pretty much everybody loves those tires. Bridgestones have some stiff a$$ sidewalls.....
Old Sep 15, 2005 | 09:58 AM
seanlaw's Avatar
seanlaw
really?? all 285/35/19 tires i've seen are above that price...what's better and where?
Old Sep 15, 2005 | 10:21 AM
The Brickyard Rat
Yup; that's exactly why I bought them; I wanted to stay with OEM sizes.
